Next-Generation Freightliner Cascadia Emphasizes Fuel Economy, Connectivity, Drivers
Heavy Duty Trucking  /  September 1, 2016
Every aspect of the next-generation Freightliner Cascadia unveiled Sept. 1 “has been re-imagined,” said Richard Howard, senior vice president of sales and marketing for Daimler Trucks North America. It’s a "completely brand new truck"... not Cascadia 2.0.
“We are raising fuel efficiency, connectivity, safety, quality and uptime performance to even greater levels, and also introducing a premium driver experience as a powerful customer benefit and driver retention tool," Howard said Sept. 1 during the introduction of the new truck in Colorado Springs.
The new truck, which will be designated a Model Year 2018, will begin production in January, ramping up to full production by March. Production of the current Cascade will continue for two years.
The next-generation Cascadia combines a new aerodynamic shape with the newest Detroit integrated powertrain for superior fuel economy. According to DTNA CEO Martin Daum, it ”is a mind-boggling 8% more efficient than the Cascadia Evolution, the current most efficient truck on the road."
Standard aerodynamic enhancements such as an upper door seal, elliptical-shaped mirrors, sloped hood, bumper with integrated air deflector and integrated antennas all minimize drag. The optional Aero and AeroX packages provide additional aerodynamic benefits to manage airflow, including longer side extenders, lower chassis fairings, drive wheel covers and proprietary-designed wheel fairings.
The new Cascadia is available with the integrated Detroit Powertrain, which combines the fuel-efficient downsped 400 hp/1,750 lb/ft. of torque Detroit DD15 [OM472] or DD13 [OM471] engines with the Detroit DT12 [Mercedes-Benz PowerShift 3] automated manual transmission, Intelligent Powertrain Management (IPM4) and corresponding Detroit steer and rear tandem axles. The new Detroit rear axles have features such as lower sump volume, gear-set coating, friction reducing gear cutting and optional Axle Lubrication Management that reduces parasitic loss and improves fuel economy.
The new DT12 has also been updated to improve fuel efficiency and reduce friction by using super-finished gears and use of low viscosity transmission oil. It also features the latest generation of intelligent powertrain management, which uses a GPS-based system to anticipate upcoming road terrain and maximize the powertrain’s ability to utilize fuel most effectively.
Focusing on the Driver Experience
DTNA said the interior of the new Cascadia has received more attention than any previous Freightliner truck. Improvements range from the layout of the gauges and switches in the driver compartment to features inside the sleeper area, including a new Driver’s Loft configuration.
Steering and handling have been improved with the driver in mind. A new front suspension provides a smoother ride and improved roll stiffness, and the steering gear is now located further forward to help improve steering precision and ultimately lead to less driver fatigue.
Switches and steering wheel controls allow drivers to work without leaning and stretching. In the instrument cluster, digital smart gauges and information displays keep drivers informed as they drive.
New noise abatement technology can be further improved with an optional insulation package using 3M Thinsulate technology. A new engine mount design provides better vibration isolation and the engine tunnel cover is now constructed using Quiet Steel technology.
The sleeper area has been redesigned to include more cabinets, with larger spaces that can accommodate standard appliances. A television swivel bracket can hold up to a 26-inch flat panel TV. Double-bunk and Driver Loft options are also available. A new cargo shelf option allows drivers to store containers or duffle bags easily. If an upper bunk is spec’d, it will come standard with an easily released telescoping ladder.
The Driver‘s Loft features a dinette table/work table and opposing seating with seat belts. These can be folded down flat quickly to allow for a murphy-style bed to swing down. The Driver’s Loft also comes standard with aircraft-inspired LED ambient lighting and dimmer switch so drivers can personalize their light levels.
DTNA didn’t forget technicians in designing the Cascadia. New splayed frame rails create more room in the engine compartment to allow easy access for maintenance tasks, and most electronic control units are now stored securely in the cab in the new eVault for easier convenience and protection from the elements. In front of the eVault is the fuse and relay box, which is easily accessible with no hand tools needed. The dash panel was designed to be easily removed, and the standard two-piece front bumper can be removed in just two minutes.
An updated, larger, engine air filter increases airflow and requires less frequent replacement intervals. Long-lasting LED lights are standard on interior and exterior.
Innovative new headlights incorporate LEDs in the low beam, high beam, daytime running lamp, park lamp and turn signal lamp. The LED provides an impressive field of view in nighttime and bad weather conditions.
Connected Performance
Detroit has developed a proprietary connectivity platform exclusively for the new Cascadia. It will facilitate the delivery of current Detroit Connect features, such as Virtual Technician remote diagnostics, plus new features designed to provide deeper insights on fuel efficiency and safety performance.
The introduction of the new platform also marks the debut of Detroit Connect Remote Updates, which enables over-the-air engine parameter programming and Detroit-initiated remote engine and other powertrain electronic controller firmware updates. Remote Updates features will be available to customers during the second half of 2017.
Also available as an option with the new Cascadia, Detroit Connect Analytics provides users with on-demand, automated fuel efficiency and safety analysis and reports featuring key insights from Detroit and DTNA engineers.
The connectivity platform will be available in the new Cascadia in January 2017.
Photo gallery - http://www.truckinginfo.com/photogallery/photos/659/freightliner-cascadia-evolution-august-31-2016.aspx
Freightliner Says New Cascadia Offers Fuel Gains, Connectivity Advancements
Transport Topics  /  September 1, 2016
Freightliner Trucks unveiled its nearly completely redesigned Cascadia tractor here that executives said is up to 8% more fuel efficient over the current Evolution model and features major advancements in a number of other key areas.
“With the new Cascadia, we have not just updated past successes. Every aspect of the truck has been reimagined. We are raising fuel efficiency, connectivity, safety, quality and uptime performance to even greater levels and also introducing a premium driver experience as a powerful customer benefit and driver retention tool,” said Richard Howard, senior vice president of sales and marketing for Daimler Trucks North America, parent of Freightliner.
"We want the new Cascadia to be 'the truck of choice for big fleets in North America,' " DTNA President Martin Daum said.
He said the model year 2018 truck will begin to hit the road in April.
Executives said the efficiency gains come from a series of enhancements, including a sloped hood and bumper with integrated air deflector to minimize drag. The new AeroX package offers additional benefits such as longer side extenders, lower chassis fairings, drive wheel covers and proprietary-designed wheel fairings.
Also introduced during a Sept. 1 press conference was Detroit Connect Analytics, available through the new connectivity platform on the Cascadia. It will provide fleets with information to identify behaviors, trends and insights on fuel consumption and safety performance data. Fleet managers can view the data for a single trip, single vehicle or their entire fleet over different periods of time.
Daum said connectivity will continue to “change the life of trucking.”
To have a “meaningful impact on the performance of either drivers or the vehicle, you need to be able to see everything and be able to consume that in a way in which you or I can understand it. Detroit Connect Analytics is our move in that direction,” said Matt Pfaffenbach, DTNA’s director of connectivity.
Also offered with the new Cascadia is the Detroit Assurance 4.0 system with active brake assist that provides full braking on stationary objects, adaptive cruise control and lane departure warning. There is also a warning should a pedestrian be picked up by the system’s radar.
In addition, Detroit’s over-the-air update capabilities, allowing customers the ability to perform remote engine parameter and other updates, will be available during the second half of 2017, the company said.
The Cascadia’s interior has received a major overhaul, starting with a centrally located hub where nearly all electronic control units are stored for easy access with no tools needed.
A new steering wheel includes one-touch buttons for key functions and is complimented by an overhauled dashboard and instrument cluster aimed at providing drivers easier-to-understand information to reduce distractions. When not on the road, an updated driver’s loft area in sleeper models has first-time features such as dimming lights.
Though the new Cascadia was officially unveiled Sept. 1, it was previewed one night earlier with 12 fleet customers that have spent a combined $9 billion with Freightliner in the past six years. Officials with a number of these large fleets were present at the event and credited Freightliner for acting on their suggested improvements.
The new Cascadia is available with the integrated Detroit powertrain, which combines the 400 horsepower and 1,750 pound-feet of torque of Detroit DD15 or Detroit DD13 engine with the Detroit DT12 automated manual transmission and Detroit steer and rear tandem axles.
“By combining advanced aerodynamics of the new Cascadia with the power of the high-performance, high-efficiency integrated Detroit Powertrain, we will help customers get the most out of every gallon,” Howard said. “We have provided an optimized, one-stop fuel efficiency solution.”
Daum said the current Cascadia will be produced for at least another two years. The new truck will be built in both Mexico and Cleveland, North Carolina.
Freightliner debuts all-new 2018 Cascadia
Fleet Owner  /  September 1, 2016
DTNA says it will deliver up to 8% improvement in fuel economy, offer fulltime connectivity
Daimler Trucks North America introduced its all-new 2018 Freightliner Cascadia by delivering 12 tractors carrying the colors and logos of its largest fleet customers during a kick-off event staged at the World Arena here. Officially dubbed the “New Cascadia,” it combines state-of-the-art electronics, advanced powertrain integration, new technologies and refined aerodynamics to deliver up to an 8% improvement in fuel economy compared to the current Cascadia Evolution, according to Martin Daum, DTNA president and CEO.
“That’s not just a marketing number, it’s been scientifically proven in rigorous testing to be measurable and repeatable,” Daum said. “Our initial goal [in developing the New Cascadia] was 5%, so the 8% we saw in testing was a mind boggling number.”
In addition to the fuel efficiency gains, the new truck features full-time connectivity tied into the company’s Detroit suite of remote diagnostic and data monitoring systems, making it “the largest mobile device on the road,” Daum said. It will also come to market with the next generation of Detroit advanced safety systems.
Initial production will begin in DTNA’s Cleveland, NC, and Saltillo, Mexico, plants early next year, slowing building to full production by mid 2017.  The current Cascadia Evolution, which will now be called the “Classic Cascadia” will also remain in production for at least two years, according to Daum.  There is a 19% spread in fuel efficiency between the base Classic Cascadia and the most efficiently speced New Cascadia, offering customers a choice in cost and performance that meets their particular operations, he said, adding that the cost spread between the basic and most advanced trucks would be $15,000.
Highlights for the new truck’s integrated Detroit powertrain start with 400-hp ratings of the Detroit DD15 or DD13 diesel engines mated to the Detroit DT12 automated mechanical transmission and new Detroit rear axles with ratios as low as 2.16.  The DT12 receives a number of internal changes to reduce friction for better fuel efficiency as well as a new generation of Detroit’s intelligent powertrain management software that incorporates GPS-enabled predictive cruise control. New gear coatings and an electronic lubrication management system are among the fuel-efficiency features of the new Detroit tandem axle, which will initially be available with a 2.28 final drive ratio followed by the 2.16 ratio later in 2017.
Using the company’s dedicated wind tunnel and computer fluid design, the New Cascadia’s cab has been fine-tuned for optimal aerodynamics, according to Kary Schaefer, general manager of product marketing and strategy. It will be offered with two aerodynamic packages, one similar to the current Cascadia Evolution but with lower clearances for front and side air dams and redesigned mirror mounts, and the other an extensive AeroX package with longer side extenders, lower chassis fairings, a new front air dam design and proprietary wheel covers and fairings.
A completely redesigned interior features a wraparound dash with integral 5-in display screen, new steering wheel controls, and extensive use of soft automotive-like finishes, as well as added storage space, dimmable LED lighting and new door seals that improve cab noise levels.  Options include a murphy bed bunk over a dinette area and 3M Thinsulate insulation for added noise and temperature isolation.
Drawing on an advisory panel of top technicians from its dealership network, the new model incorporated a number of their suggestions to ease maintenance and increase vehicle uptime. “You can’t beat physics – every machine has to be serviced, but you can design for quicker, better servicing,“ said Toby Faulkner, dir. of New Cascadia development. Those design elements include a single centralized compartment for all electricals including all ECUs that can be accessed from within the cab by removing a single panel without any hand tools. Frame rails have been splayed in the engine compartment for easier access to accessories, the entire HVAC system can be reached though a panel on top of the dash, and a new front bumper can be removed by one person in two minutes, according to Faulkner. Use of LEDs for all exterior lighting including headlights also reduces maintenance requirements.
Advanced safety systems available in the New Cascadia include the next generation of the Detroit Assurance suite that now offers full emergency braking on stationary objects, adaptive cruise control and lane departure warning all using a new version of a proprietary Daimler radar sensor.
While the improved fuel efficiency, driver comfort features and advanced safety systems are impressive, the new truck’s connectivity features are so extensive they require an article of their own.  But in outline, DTNA is moving away from a subscription model and will instead provide five years of full-time connectivity as standard on the New Cascadia. That package will include its Virtual Technician remote diagnostics, a new Detroit Portal that will allow fleets to integrate data more easily into their own systems, and remote updating of firmware and vehicle performance parameters. An optional Detroit Connect Analytics will also be launched next year, offering fleets insights into vehicle, driver and fleet performance.
“This is a completely brand new truck, “said Richard Howard, DTNA sr. VP of sales and marketing.  “With the new Cascadia, we … are raising fuel efficiency, connectivity, safety, quality and uptime performance to even greater levels, and also introducing a premium driver experience as a powerful customer benefit and driver retention tool.”
Photo gallery - http://fleetowner.com/equipment/new-cascadia-preview-welcome-future#slide-0-field_images-199801
‘True connectivity’ a key feature of new Cascadia
Detroit Connect Analytics offers operational insights to fleet customers
Along with all of the hardware innovations designed to position the new Freightliner Cascadia as the best fleet truck on the market, a new connectivity platform will provide customers with important insights about their vehicles and help them make critical business decisions.
Detroit Connect Analytics, introduced Thursday, is part of the Detroit Connect suite of connected vehicle services and accessible via a dedicated section of the new Detroit Connect portal, Daimler Trucks North America representatives explained in a media briefing here.
“There is a very noticeable tension between technology as it exists today and where it can possibly go tomorrow,” said Matt Pfaffenbach, DTNA director, connectivity, who likened the evolution of vehicle connectivity to the early days of the graphical user interface in personal computers, where a computer mouse went unused until the applications were available to take full advantage. “There’s a tremendous potential here, and we can see a certain direction as to where connectivity goes—but our customers have needs today. So how do we balance that? How do we drive toward towards a certain direction, yet deliver something that the customer needs?”
Whereas the new Cascadia is designed around the drivers needs in the cab, connectivity is a tool for other key members of the fleet: executives, operations, safety, and maintenance.
“We want to provide them a trusted source of data,” Pfaffenbach said. “With the new Cascadia, I’d like to say ‘Welcome to true connectivity.’ It is both the hardware in the truck as well as the user experience in the back office.”
With five years of service included in with every new Cascadia, Analytics provides users with on-demand, automated fuel efficiency and safety analysis and reports featuring key insights from Detroit and Daimler Trucks North America engineers.  Analytics uses that expertise to quickly identify behaviors, trends, root causes and key insights on fuel consumption and safety performance data across the fleet.
The data provides easy-to-read analysis and recommendations for improving vehicle and fleet performance, including the identification of “outliers,” or vehicles whose performance doesn’t match up with similar vehicles in the fleet. Fleet managers can view the data for a single trip, single vehicle or their entire fleet over different periods of time.
Fuel efficiency performance data analyzed includes engine speed, idle time, cruise control, engine power, integrated powertrain performance and driver interaction. The safety data is collected from all available safety systems, including the Detroit Assurance suite of safety systems, and includes collision mitigation braking, lane departure warning, distance violations and speed violations.
Pfaffenbach characterized the data delivery method of the original Virtual Technician as “a good first step, but somewhat cumbersome.”
 “As you can imagine, with a large fleet those email messages going back and forth [from the Detroit Customer Support Center] become a very difficult means of communication. With the new Detroit Connect portal, we put the most critical information directly in front of the customer,” he said. “Customers can spend less time crunching data and more time optimizing vehicle performance. The ability to unlock and understand what’s happening with the truck and use that knowledge to make adjustments is a significant time and performance advantage.”
Detroit Connect Analytics will be included within different service option packages with the new Cascadia that will deliver the fuel efficiency features only or both fuel efficiency and safety features.  Detroit Connect Analytics will be available for use with the new Cascadia beginning Q1 2017. It will be available with other Freightliner and Western Star models later in 2017.
For more information, go to www.DemandDetroit.com/Connect.
Freightliner unveils brand new Cascadia
Today’s Trucking  /  September 1, 2016
Freightliner may have drawn on a familiar name when unveiling the 2018 Cascadia, but the company’s newest truck promises to boost fuel economy, improve driver comfort, and leverage electronic tools like never before.
“We have changed almost everything on this truck,” says Richard Howard, senior vice president – sales and marketing for Daimler Trucks North America, referring to the 2018 Model Year designs that begin production in early 2017. “Starting with the best truck is the best place to start.”
It has already attracted some of North America’s biggest truck buyers, too. The first 2018 Cascadias have been purchased by 12 fleets that collectively operate one out of every four of the previous Cascadia models. Canada’s Bison Transport is among those buyers.
 “This is a great-looking truck,” said Don Streuber, Bison’s executive chairman and CEO, as fleet executives crawled over the first of the new models. “We’re excited to bring it into our fleet and we’re excited for the fuel economy it will bring.”
Daimler has not expressed the potential fuel economy in miles per gallon, since everything from weather to loads and roads can play a role in that. But a test run between Detroit, Michigan and Portland, Oregon showed that the new Cascadia betters the Cascadia Evolution’s fuel economy by a full 8% thanks to spec’s including a new AeroX aerodynamic package with long flex extenders, drive wheel fairings, air dam below the front bumper, and a 2.16 ratio, the company says.
The boosted fuel economy is no small feat. The original target was to better the fuel economy by 5%, and the Cascadia Evolution had already been recognized as Freightliner’s most fuel-efficient model.
The most fuel-efficient versions of them all will be identified with a blue “I” in the Cascadia name badge. That will mean the truck combines an integrated Detroit powertrain and an Aero package or upgraded AeroX package.
Underneath, the integrated Detroit powertrain combines downsped 400-horsepower/1,750 lb-ft Detroit DD15 or Detroit DD13 engines with the Detroit DT12 Automated Manual Transmission, and Detroit steer and rear tandem axles. Direct Drive ratios of 2.28 and 2.16 are available, while an overdrive comes in 2.85. Optional axle lubrication management systems will help to further improve fuel economy by reducing parasitic losses.
Compared to the base model Cascadia on the road today, a 2018 Cascadia that leverages all available aerodynamic and powertrain enhancements will cost another $15,000 but boost fuel economy by 19%, says Martin Daum, president and CEO of Daimler Trucks North America.
Beyond fuel economy
The changes have not been limited to fuel economy alone. A new front suspension has been included for a smoother ride, and the steering gear has been moved forward to improve turns.
Inside the cab, an enlarged driver information display can be controlled with simple buttons on the steering wheel, and offers information using plain English rather than speaking in codes. If a driver drifts over pavement markings, the display will show a corresponding red line next to a truck icon, and that will be combined with an audible rumble. Yellow and red trailer icons appear when following distances are too close for comfort. And even those vary by conditions. At 45 miles per hour, for example, the warning will sound if the truck is within 2.7 seconds of a vehicle ahead of it for longer than 10 seconds. Slower speeds allow closer distances.
“The reason we have a 10-second lag is because we all know of cars coming in and out,” says Scott Kuebler, general manager – component sales.
The information on following distances comes from Detroit Assurance 4.0 radar, which boasts a 250-meter range compared to its predecessor’s 200 meters. Active Brake Assist will now fully apply the brakes to help avoid collisions with stationary objects, while warnings will be sounded about nearby pedestrians. That’s just one generation behind a Daimler system in Europe that also actively brakes when identifying pedestrians.
The warnings are not for drivers alone. The same information on the dash display can be shared through telematics systems, and fleets will be able to alter the parameters they want included in the reports.
Anyone who wants Detroit Assurance, however, will have to have a Detroit powertrain,” Kuebler adds. “If you want [Meritor Wabco] OnGuard, in the new Cascadia, it’s with a Cummins engine.”
Enhancements to the truck’s visibility extend beyond electronic tools as well. The windshield is 12% bigger than that found on the current Cascadia, and the headlights are LEDs. Options are also available to heat the hood mirrors, to keep them clear of ice and snow.
Driver comfort
Truck features involve more than performance alone. Many specifically focus on the driving experience. And that makes the 2018 Cascadia a powerful recruiting and retaining tool, says Kary Schaefer, general manager – product marketing and strategy.
The new truck will come with three trim packages, including a standard Professional level, and optional Elite exterior and interior packages.
Unwanted buss, squeaks and rattles – including those that some drivers have noticed in existing Cascadia sleepers – have been tackled by incorporating everything from a third door seal to an optional layer of 3M Thinsulate insulation. Engine mounts have also been enhanced, while the cover of the engine tunnel is made with something known as Quiet Steel technology.
Additional storage space and the layout inside the cab emerged through a partnership with Teague, which is known for designing Boeing aircraft interiors.
There are bigger spaces to accommodate larger microwaves and fridges, and the interior is lit with dimmable LED bulbs. There are even three cup holders up front, compared to the previous Cascadia’s two.
Back in the sleeper, an optional dinette area can be transformed into a murphy bed in about 10 seconds. Two seats flip down, the table lowers, and a bunk that otherwise sits against the back wall drops into place over it all. When the dinette is assembled, one of the two seats is also positioned at an angle, ensuring that legs don’t tangle under the table. It all betters an earlier attempt to provide such an option in the existing Cascadia. “It was kind of a pain to put down and put away, and the mattress wasn’t very comfortable,” Schaefer admits. The seats in the updated version can also lift to reveal storage down below.
For those who don’t need a top bunk there is the option of dedicated storage shelves with a lip. When an upper bunk is spec’d, it can be accessed with a sturdy telescopic ladder. And a swivel bracket has been installed to support up to a 26-inch flat panel TV.
Mechanical fitness
Other features were designed specifically with mechanics in mind.
 “At the end of the day it’s still a machine, and we get that, and every machine has to be serviced,” said Toby Faulkner, director – new Cascadia development.
Those features include splayed frame rails to improve access around the engine compartment. And most Electronic Control Units are now stored in a new eVault, behind the fuse and relay box that can be accessed without hand tools. Inside the cab, HVAC blower motors can be accessed by simply removing a top panel on the dash.
The new two-piece bumper can even be removed by a single person, and that feature came from a focus group of technicians.
“This is one we [initially] got wrong, and the technicians were very clear we had to go back to the drawing board,” he said.
Connectivity for the masses
Matt Pfaffenbach, director of connectivity, refers to the truck’s new Detroit Connect Analytics system as “connectivity for the masses”, which will deliver vehicle data through a portal for maintenance managers, fuel managers, safety officers, and fleet managers alike. That will be launched this fall. And every 2018 Cascadia owner will receive the service for five years, effectively covering the first life of the vehicle.
The system will focus both on fuel economy and safety. If a truck is performing better or worse than a counterpart with similar spec’s, fleets will receive a warning and the data to understand why. “That gives a good analysis of apples to apples,” he says, referring to the way fleets can compare common spec’s and similar operating conditions. “We can then identify the vehicles that are outliers.”
Remote diagnostics will be available through the Virtual Technician system. Also coming next year will be the ability to remotely update engine, transmission and aftertreatment firmware, and fleet parameters governing road and cruise speeds, cruise power and speeds, idle shut down, and temperatures. No wires required.
It all adds up to a product that plays an important role in Freightliner’s future. The Cascadia that is on the road today was recognized as playing a key role in giving Daimler Trucks North America a 42.6% Class 8 market share.
Think of it as an important evolution for the Evolution.
First look: 2018 Freightliner Cascadia
Commercial Carrier Journal (CCJ)  /  September 1, 2016
When Freightliner Trucks introduced the first Cascadia in May 2007, the company said it would offer 3 percent fuel savings over the Columbia and Century Class models it ultimately would replace. The OEM’s flagship truck has matured over the last nine years with a number of fuel efficiency- and emissions-related improvements.
When Martin Daum, president and CEO of Daimler Trucks North America introduced the company’s newest iteration of the Cascadia in front of a group of dealers, press and its executives from 12 of Freightliner’s largest fleet customers at an event in Colorado Springs on Wednesday, he boasted the new 2018 model-year truck could achieve significant fuel efficiency gains over the best-spec’d 2016 Cascadia Evolution as demonstrated in a 2,400-mile road test earlier this summer that netted 8 percent better fuel consumption.
The Cascadia has earned a solid reputation, particularly among fleet customers, and the possibility of a major leap in fuel efficiency certainly earned the attention of the fleet executives in the room, who soon after were released to climb aboard their new rigs and experience the model-year changes for the first time.
Despite the potential leap in fuel efficiency, the new truck is still a Cascadia at heart and is built on the same frame as its predecessor. The fuel efficiency gains stem largely from advancements in powertrain technology and aerodynamic improvements, many of which are the realization of efforts from DTNA’s participation in the U.S. Department of Energy’s first SuperTruck project.
We spoke with several fleet executives in attendance to gauge their initial reaction to the new Cascadias. Here’s what they had to say:
  • Derek Leathers, CEO, Werner Enterprises: “My first impression is very positive. I like the look of it – sleeker and more modern – a nice next take from the previous model. I’m 6’ 5” and loved getting inside and walking around and experiencing the roominess and some of the new cabinetry and features.”
  • Chad England, CEO, C.R. England: “Everything from the design on the dash seems to be enhanced and simpler, more like driving a car. I think drivers are going to love it – there is more space. For solo drivers, the table option is cool.”
  • Max Fuller, chairman and CEO, U.S. Xpress: “I saw it two years ago when it was a concept on a pasteboard, but seeing the product for the first time – the Cascadia really made a big improvement on the previous product that [Freightliner] had and they continue to go forward and set new standards on fuel economy and diagnostics. Looking at this truck it should be a lot easier for the mechanic to work on. They really are thinking about the mechanics and how quickly you can get the trucks back on the road. The dash layout is cleaner, it’s easier to reach the controls and buttons and they’ve made some changes to the seats and now they have two grab handles to get in and out.”
  • Dave Williams, vice president of equipment, Knight Transportation: “The aerodynamics of the truck have changed substantially in the last decade. There is a lot of fine-tuning that goes on. We’ve learned through the process that little nips and tucks are important for improving fuel economy but it also has to look good because there is an emotional element to buying. At first glance it meets the task. There are sharper lines than the previous version that was more rounded. Recruiting and retention issues aren’t going to be solved by a truck, but it can make [truck driving] a little bit better of a job. Anything we can do to make a driver feel more at home, safer, more comfortable and more productive is what we are after. Obviously that is the intent here.”
Impressions from a morning ride-along
While DTNA wasn’t ready to hand us the keys to one of the new 2018 Freightliner Cascadias just yet, we were afforded an opportunity for a ride-along on the interstate around Colorado Springs. Our tractor was an Aero version 72” raised roof sleeper cab with the Elite interior trim package and the Detroit integrated powertrain, which included a 2.28:1 ratio 6×4 rear axle configuration, DT12 automated manual transmission and DD15 engine rated at downsped 400-hp/1,750 lb-ft torque.
The DT12’s skip shift feature got us up to speed quickly as we pulled from the traffic light and onto the interstate onramp. Once we were underway, the first thing that stands out is the noise, or more accurately, the lack of it. Thanks to the third door seal and 3M Thinsulation, we didn’t have to raise our voices to be heard during our conversation with Lee Gannant, technical service advisor for Detroit and our driver for the morning.
Navigation on the new 5-inch instrument display – located directly in front of the driver in the middle of the instrument cluster panel – is a snap with steering wheel-mounted controls that toggle between the different menu items such as diagnostics, audio controls, driving assistance, setup options, trip information and more.
Our tractor was equipped with the optional Detroit Assurance safety package which includes active braking assist, lane departure warning and adaptive cruise control feature that monitors traffic up to 250 meters in front of the vehicle using radar on the front bumper. If the system detects a vehicle in front of the truck, the information display shows its approximate distance and road speed and adapts speed automatically.
Adaptive cruise control worked well during our demonstration ride as we eased along in the right lane at 65 mph and cars darted in and out in front of us, but never to the point that the system had to engage the service brake. You could certainly feel the engine brake activate when a slower car caused the system to reduce speed, but we decelerated at a natural rate and quickly returned to our set 65 mph cruising speed once the slower car exited the interstate, all without Gannant ever having to touch the controls or brake and accelerator pedals.
Unfortunately, the flat route we took around the base of the foothills east of the Rocky Mountains didn’t lend itself to demonstrate the DT12 transmission’s newest-generation intelligent powertrain management (IPM4) that uses GPS technology to anticipate changes in road terrain and adapts transmission and engine functions to optimize fuel efficiency as it crests and descends hills. But you can expect future coverage on that and other new features as a media test drive event is in the works for the near future.
Freightliner unveils revamped, redesigned 2018 Cascadia
Not resting on its 42.6 percent U.S. and Canadian Class 8 year-to-date market share, Daimler Trucks North America (DTNA) unveiled Wednesday its reimagined 2018 Freightliner Cascadia tractor, ushering in what DTNA President and CEO Martin Daum calls “the new frontier for fuel efficiency,” with up to 8 percent better fuel economy performance over the current-model Cascadia Evolution.
“Every aspect of the truck has been re-imagined,” says Richard Howard, senior vice president of sales and marketing for DTNA. “We are raising fuel efficiency, connectivity, safety, quality and uptime performance to even greater levels.”
Freightliner shared the spotlight Wednesday night at Broadmoor Arena in Colorado Springs with 12 of the company’s largest volume customers – U.S. Xpress, Heartland Express, Schneider, Bison Transportation, Old Dominion, Prime, Inc., Werner, Swift, Knight Transportation, C.R. England, Crete and J.B. Hunt – each of whom purchased the new Cascadia sight unseen early in the development process.
Collectively, these 12 customers have ordered one of every four of the 275,000 Cascadias built since 2011, investing more than $9 billion into Freightliner trucks in that time.
Cascadia powertrain
The new Cascadia is available with the integrated Detroit Powertrain that includes GHG 2017-compliant Detroit DD15 or Detroit DD13 engines, updated Detroit DT12 automated manual transmission, fourth-generation Intelligent Powertrain Management (IPM4) and Detroit steer and rear tandem axles.
The updated IPM4 transmission management software now uses GPS-based technology to maximize the DT12 fuel economy performance by anticipating changes to road terrain. The transmission also has super-finished gears to allow for lower-viscosity transmission oil.
Changes to the rear axle include a lower sump volume, gear-set coating, friction reducing gear cutting and optional Axle Lubrication Management that reduces parasitic loss.
New Detroit rear drive axle ratios 2.28 and 2.16 are available in the new Cascadia to further promote downspeeding and thus improved fuel economy.
Updated to the DT12 improve fuel efficiency and reduce friction by using super- finished gears and use of low viscosity transmission oil. It also features the latest generation of IPM4, which uses a GPS-based system to anticipate upcoming road terrain and maximize the powertrain’s ability to utilize fuel most effectively.
Exterior styling
On the outside, the new Cascadia gets a fresh, aerodynamic shape with dozens of sleek new updates, designed to specifically to drive fuel efficiency gains.
Standard enhancements such as an upper door seal, elliptical-shaped mirrors, sloped hood, bumper with integrated air deflector and integrated antennas all minimize drag. Optional Aero and AeroX packages provide additional aerodynamic benefits to manage airflow, including longer side extenders, lower chassis fairings, drive wheel covers and proprietary-designed wheel fairings.
Interior enhancements, improved ergonomics
While the exterior styling is a notable departure from previous generation Cascadias, Daum says DTNA recognizes its role in helping customers with driver recruiting and retention, and much of the design process was focused behind the steering wheel.
“Drivers are our job, too,” said Daum. “Being on the road for 10 days and sleeping in a truck can be brutal, and we have to make that job easier for drivers. [Truck driving] is potentially one of the toughest jobs you can have in North America. We invested a lot of money in the sleeper, the dashboard … into the human machine.”
DTNA partnered with Teague, designer of Boeing airplane interiors, to develop the interior of the new Cascadia on lighting, storage and ergonomic features. Additional grab handles improve driver ingress and egress, and new ceiling-mounted LED lights offer more diffuse ambient cabin illumination to reduce eye strain.
An ergonomically designed wraparound dashboard includes switches and steering wheel controls that are designed to allow drivers of all sizes to work without leaning and stretching. The instrument cluster features digital smart gauges and information displays.
A new 5-inch display on the instrument cluster panel provides plain text messaging rather than numeric fault codes and is navigable with steering wheel-mounted controls that also handle phone and radio commands.
The new Cascadia is even quieter than prior generations. Kary Schaefer, DTNA general manager of product marketing and strategy, credits noise abatement to an insulation package using 3M Thinsulate technology. A new engine mount design provides better vibration isolation and the engine tunnel cover is now constructed using Quiet Steel technology. DTNA also added a third door seal to lower interior cab noise.
Available in a variety of cab configurations, the new Cascadia offers customizable living-space options, including a redesigned sleeper area that include more cabinets, as well as larger spaces that can accommodate standard appliances. For entertainment, a television swivel bracket can hold up to a 26-inch flat panel TV for movie- theater-like viewing.
Double-bunk and Driver Loft options are also available. The Driver’s Loft features a dinette table/work table and opposing seating with seat belts. The seats can be folded flat to allow for a murphy-style bed to drop down. The Driver’s Loft also comes standard with aircraft-inspired LED ceiling-mounted ambient lighting at provides more diffuse illumination for reduced eye strain and a dimmer switch so drivers can personalize their light level.
A new cargo shelf option allows drivers to store containers or duffle bags easily. If an upper bunk is spec’d, it will come standard with a telescoping aluminum ladder to aid egress into the upper bunk.
An uptime design
Toby Faulkner, director of the new Cascadia’s development, says the new truck was designed with input from nine Freightliner master technicians, who each inspected and rated components for ease of serviceability and maintenance improvement recommendations.
The technicians looked over 72 key points during the design and prototype phases, which helped drive designs innovations for the new model.
Among the first changes was the integration of splayed frame rails versus the straight frame rails on today’s Cascadia, which create more room in the engine compartment to allow technicians easier access for maintenance.
Most electronic control units are now stored in the cab in the new eVault for easier convenience and protection from the elements. In front of the eVault is the fuse and relay box which is accessible without hand tools. To increase dash component accessibility, the dash panel was designed to be easily removed. Additionally, the standard two-piece front bumper of the Cascadia can be quickly removed within two minutes.
“It says it best when a guy who actual does the work comes back and says it’s a game-changer,” Faulkner says.
An updated, larger, engine air filter increases airflow and requires less frequent replacement intervals. Standard, interior and exterior LED lights further add to the Cascadia’s ease of maintenance.
Faulkner says the new generation truck was heavily tested in extreme temperatures designed to stress the truck’s performance in worse-case scenario real world conditions.
“We spent a lot of months in really cold temperatures to see what kind of traction control issues we might have, issues with any fuel line freezing,” he says, adding the truck was also tested in Arizona in temps upwards of 125 in order to tax the HVAC system and other internal components in extreme heat conditions.
Improved safety
The new Cascadia uses a full LED system, including headlights that incorporate LEDs in the low beam, high beam, daytime running lamp, park lamp and turn signal lamp.
A one-piece windshield design increases wiper coverage by 12 percent over the current Cascadia and is specially constructed to provide increased resistance to breakage. Both the one-piece windshield and one-piece door glass provide an unobstructed view to the mirror and road. “There’s a significant improvement in visibility,” Schaefer says.
The optional Detroit Assurance 4.0 suite of safety systems includes Active Brake Assist that now provides full braking on stationary objects, Adaptive Cruise Control and Lane Departure Warning with optional video capture. The proprietary safety suite includes driver-friendly controls and is seamlessly integrated into the truck’s dashboard, engine and transmission electronics and can enhance driver safety by mitigating collisions.
Detroit Assurance safety event reporting can be accessed using Detroit Connect Analytics, which will be available to customers early next year. Safety event reporting available through Analytics can be viewed using the new Detroit Connect portal, informing fleet managers and further enhancing driver safety performance.
Always connected, always online
The 2018 Cascadia features an exclusive proprietary connectivity platform introduced by Detroit just for the new model. The new platform will facilitate the delivery of current Detroit Connect features, such as Virtual Technician remote diagnostic service, as well as new features designed to provide deeper insights on fuel efficiency and safety performance.
“The biggest mobile device on the road will be the new Cascadia,” says DTNA Senior Vice President of Sales and Marketing Richard Howard.
“Welcome to real connectivity,” says Matt Pfaffenbach, DTNA director of connectivity. “It is both hardware in the tuck as well as user experience in the back office.”
The introduction of the new platform also marks the debut of Detroit Connect Remote Updates, which enables over-the-air engine parameter programming and Detroit-initiated remote engine and other powertrain electronic controller firmware updates. Remote Updates features will be available to customers mid-next year.
Also available as an option with the new Cascadia, Detroit Connect Analytics provides users with on- demand, automated fuel efficiency and safety analysis and reports featuring key insights from Detroit and DTNA engineers.
The connectivity platform will be available with start-of-production of the new Cascadia in January. A five-year standard base package includes Virtual Technician, access to the new Detroit Connect portal and – later in 2017 – Remote Updates.
Detroit Connect Analytics will be available within different service option packages with the new Cascadia, one that will deliver the fuel efficiency features only and one that will include both fuel efficiency and safety features. Detroit Connect Analytics will be available for use with the new Cascadia in early 2017.
Pfaffenbach says Detroit Connect Analytics offers the ability to see and consume information on fuel economy and safety performance of a trip, the life of the truck or for the entire fleet.
“What we do with the tool is not only gather the information, but also attempt to explain why a certain vehicle performed well or did not perform well,” he says.
Fuel economy improvements, independent testing
DTNA conducted hundreds of hours of testing in its proprietary, state-of-the-art wind tunnel and millions of miles of real-world on-highway testing, to evaluate and design the new Cascadia, Schaefer says.
A pre-launch test that spanned six days and 2,400 miles in a trip from Detroit to Portland, Ore. pitted a 2018 Cascadia against a 2016 Cascadia Evolution, currently the most fuel efficient truck on the road. The new truck, Schaefer says, proved to consume 8 percent less fuel than the Cascadia Evolution.
While the 2018 Cascadia does offer improvement over its Cascadia Evolution sibling, Daum says there are no plans to stop building Cascadia Evolution for at least the next two years.
Production on the new Cascadia begins in January and will ramp up through spring 2017.
Photo gallery - http://www.ccjdigital.com/freightliner-unveils-revamped-redesigned-cascadia-will-come-to-market-in-2017/
Freightliner takes wraps off new Cascadia
Truck News  /  September 1, 2016
New Cascadia achieved 8% better fuel mileage than the Cascadia Evolution on cross-country run
Freightliner has completely redesigned its top-selling truck with the introduction of the 2018 Cascadia.
The company showed the new Cascadia – as it has officially been dubbed – for the first time to customers, dealers and truck press at a special event here this week. Twelve carriers, including Bison Transport, that have collectively spent US$9 billion on some 60,000 Freightliner Cascadias over the last six years were the first to receive the new model.
“You don’t spend $9 billion on a good vibe,” said Martin Daum, president and CEO of Daimler Trucks North America. “What sells a truck is to have the absolute best product in the market.”
Freightliner wasn’t content to have the top-selling Class 8 truck in its stable; it set out to improve fuel economy by 5% compared to the Cascadia Evolution. A real-world coast-to-coast trip from Detroit to Portland yielded an 8% fuel economy advantage for the new Cascadia, exceeding the company’s own expectations.
Gains came from improved aerodynamics, enhancements to the DT12 automated transmission, elliptical-shaped mirrors, a new upper door seal and integrated antennas.
Freightliner will continue to offer the current Cascadia and the Cascadia Evolution, giving customers a choice from a range of on-highway trucks that span a fuel economy breadth of 19%. This marks the most expansive line of on-highway tractors in Freightliner’s history, noted Richard Howard, vice-president of sales and marketing. He acknowledged the Cascadia helped DTNA grow its Class 8 market share from 34.5% in 2007 when it was launched to 42.6% through July of this year.
“Starting with the best truck is the best place to start,” he said of the redesigned Cascadia, noting nearly everything inside and outside the truck has been changed.
The engine has been lowered thanks to a splayed frame rail, which also offers better access to underhood components. The lower seating of the engine allows for a rounder front end of the truck, which differentiates the new Cascadia, giving it a more modern – but not radically so – look. The new Cascadia is available in Professional and Elite trim and with optional Aero and AeroX aerodynamic packages. Every truck will come loaded with Detroit Connect telematics and will be constantly connected, Howard explained.
“The biggest mobile device on the road will be the new Freightliner Cascadia,” he said. Detroit is upgrading its telematics with the launch of a new portal that will allow customers to manage Virtual Technician remote diagnostics and monitor key data points. For example they’ll be able to easily identify performance outliers within the fleet and investigate poor performing trucks.
Virtual Technician will be offered for five years on the new Cascadia with no subscription fees. Customers will also be able to receive remote engine updates and will be able to select a new Detroit Analytics service that aims to convert data from the fleet into meaningful information.
The interior has been completely redesigned. Kary Schaefer, general manager, product marketing and strategy, said Freightliner worked closely with interior design firm Teague, which specializes in designing small spaces and has done such work with Boeing. LED lighting is standard on the interior and exterior of the new Cascadia and dimmer switches allow drivers to adjust the bunk lighting.
Two seats and a table provide a comfortable workspace or dining area but they fold away to allow a Murphy bed to be deployed in about six seconds. In single bunk sleepers, drivers enjoy a redesigned “loft” area with ample upper storage and larger areas for clothing, TV, microwave and refrigerator.
“Driver turnover and wages are a big part of fleet costs,” said Schaefer. “We wanted to develop a truck that drivers are proud to drive. We want to think of it as a tool for attracting and retaining new drivers for fleets.”
The sleeper is also configurable for team drivers. A new telescoping ladder allows safer and easier access to the top bunk and folds neatly away when not in use.
The new driver display is extremely vibrant, and uses bright colors to communicate important messages to the driver. Fault code information is presented in plain English (or French, or Spanish) instead of by code. Also new is a fully adjustable steering column.
“We spent a lot of time on the dash layout trying to understand where the placement of switches and gauges need to be for different heights and sizes of drivers,” Schaefer noted.
A third door seal has been added to reduce noise and a redesigned suspension offers a smoother ride. A new thinsultate insulation package is also now available. The AeroX package offers a full set of low-to-the-ground fairings, which would appear at first glance to be impractical in a Canadian winter. But officials said the low front air dam was tested extensively in a Minnesota winter and it was able to snap back into place undamaged after making contact with snow and ice. The truck can be ordered without the low air dam but it contributes up to a 1% improvement in fuel economy.
The new Cascadia will be available with Detroit Assurance 4.0, an updated collision mitigation system that will now be able to identify pedestrians and apply partial braking. The radar range has been extended by 50 meters.
The truck was also built for easier serviceability. The input of technicians was sought and applied to the design, according to Toby Faulkner, program leader for the new Cascadia. Some of the design attributes that were based on technician feedback include a two-piece, easy to remove front bumper that can be removed in two minutes. All electronic control units (ECUs) are now housed together in an easy to access electronics vault accessible from inside the cab. The HVAC is also easier to access through a panel on the top of the dash.
The new Cascadia will enter production in early 2017 with production ramping up in the second quarter. It will cost approximately US$15,000 more than today’s Cascadia Evolution, depending, of course, on how it is spec’d. But even with the upcharge, an 8% fuel economy improvement is something many fleets will find difficult to ignore. And the gap could widen. Schaefer said the truck was built with the potential to add further fuel economy improvements every couple years.
Detroit DT12 transmission offers improved fuel efficiency, reduced friction
Freightliner’s newly unveiled Cascadia, which was revealed Sept. 1 in Colorado Springs, Colo., brings a lot of new technology, driver and safety enhancements to the table, including the Detroit’s DT12 [Mercedes-Benz PowerShift 3] automated manual transmission.
Part of the Detroit Powertrain, the DT12 is combined with the fuel-efficient downsped 400 hp/1,750 lb/ft. of torque Detroit DD15 or DD13 engine, Intelligent Powertrain Management and corresponding Detroit steer and rear tandem axles.
The DT12 was updated to use super-finished gears and low viscosity transmission oil to help improve fuel efficiency and reduce friction.
“By combining advanced aerodynamics of the new Cascadia with the power of the high-performance, high-efficiency integrated Detroit Powertrain we will help customers get the most out of every gallon,” said Richard Howard, senior vice-president of sales and marketing for Daimler Trucks North America. “We have provided an optimized, one-stop fuel efficiency solution.”
Fuel efficiency, performance and safety focus of Detroit Assurance 4.0
As part of the unveiling of its new Cascadia truck, Freightliner underscored the importance of fuel efficiency, performance and safety with its flagship vehicle, and are offering the latest version of Detroit Assurance 4.0 to emphasize this effort.
Detroit Assurance 4.0 offers customers several driver-friendly controls, an interactive dash display, as well as driver assist safety features like active brake assist, adaptive cruise control and lane departure warning.
“We are driven to find and develop the right solutions that maximize truck, powertrain and driver performance,” said Kary Schaefer, general manager of marketing and strategy for Freightliner and Detroit Brands, Daimler Trucks North America. “That dedication goes beyond fuel savings; it also centers on active safety systems like Detroit Assurance that protect everyone on the road.”
Assurance is integrated with the Detroit engine, transmission, braking system and dashboard to provide drivers with enhanced safety and collision mitigation technology.
There is also an optional video-capture feature that records safety related events for 20-30 seconds before, during and after an incident, which is available through the Bendix SafetyDirect web portal, which the company said would help inform fleet manager of possible driver training opportunities.
“There are so many challenges that drivers face on the road today, including the performance of other drivers and road conditions,” said Schaefer. “We will continue to improve our safety offerings to help drivers return home accident-free.”
I was part of a test drive that demonstrated Detroit Assurance 4.0 in action in a Freightliner Cascadia in Colorado Springs, Colo., Sept. 1, and along with providing a smooth ride, the vehicle, while utilizing the adaptive cruise control feature, was able to maintain not only a steady speed on various road grades, but also a safe distance from other vehicles on the highway, all with the driver’s foot off the pedals.
Even coming off the highway on an exit ramp, Assurance was able to continuously reduce the speed of the Cascadia, recognizing the slower moving vehicles ahead.
The truck was able to maximize its fuel efficiency by lowering its RPMs depending on the grade of the road, minimizing them while on a down or level slope and producing more power while traveling uphill to maintain the set cruising speed.
When the driver approached a vehicle from behind, Assurance was able to provide a notification when they were traveling too closely and reduce speed to back away and maintain a safe distance.
Fleets can set a following distance with the adaptive cruise control feature between 2.6 and 3.4 seconds in set intervals, depending on various driving conditions.
Assurance 4.0 tracks up to 40 objects simultaneously, up to 825 feet in front of the truck, while identifying the Top 6 vehicles by level of threat, with a speed, distance and time refresh rate of 200 times per second.
Coming standard is the radar system, with active brake assist, full braking on stationary objects, moving pedestrian warning, adaptive cruise control and tailgate warning. The camera system is option, which provides lane departure warning and video capture with Bendix SafetyDirect.
The Assurance 4.0 integrates into Freightliner’s new Cascadia equipped with a Detroit engine with either a DT12 or manual transmission.
The new Cascadia
Freightliner pushes Innovation with new Cascadia
Daimler Press Release  /  September 1, 2016
The new Cascadia is the most advanced truck Freightliner has ever designed, and will further lower the Real Cost of Ownershipsm for customers. Freightliner leveraged the global expertise of Daimler AG, as well as conducted hundreds of hours of testing in Daimler Trucks North America’s proprietary, state-of-the-art wind tunnel and millions of miles of real-world on-highway testing, to evaluate and design the new Cascadia.
“Many of the new Cascadia enhancements are the direct result of feedback from customers, dealers, service technicians and historical data”
Richard Howard, Senior Vice President of Sales and Marketing bei Daimler Trucks North America
Powering Efficiency
When developing the new Cascadia, engineers set a priority goal of achieving significant fuel savings over the already industry-leading Cascadia Evolution by conducting robust testing, research and development.
The new Cascadia is available with the integrated Detroit™ Powertrain, which combines the fuel-efficient downsped 400 hp/1,750 lb/ft. of torque Detroit™ DD15® or Detroit™ DD13® engines with the Detroit™ DT12™ automated manual transmission, Intelligent Powertrain Management (IPM4) and corresponding Detroit™ steer and rear tandem axles. The new Detroit rear axles have features such as lower sump volume, gear-set coating, friction reducing gear cutting and optional Axle Lubrication Management that reduces parasitic loss and improves fuel economy.
The new DT12 has also been updated to improve fuel efficiency and reduce friction by using super-finished gears and use of low viscosity transmission oil. It also features the latest generation of intelligent powertrain management (IPM4), which uses a GPS-based system to anticipate upcoming road terrain and maximize the powertrain’s ability to utilize fuel most effectively.
World-Class Aerodynamic Design
he new Cascadia has a fresh, aerodynamic shape with dozens of sleek new updates, selected specifically to push fuel efficiency to the next level. Standard enhancements such as an upper door seal, elliptical-shaped mirrors, sloped hood, bumper with integrated air deflector and integrated antennas all minimize drag. The optional Aero and AeroX packages provide additional aerodynamic benefits to manage airflow, including longer side extenders, lower chassis fairings, drive wheel covers and proprietary-designed wheel fairings.
“When you take a look at the new Cascadia, you’ll first note its modern lines and refined styling. But take a closer look, and you’ll see the attention that was given to every detail of the truck to create an aerodynamic vehicle that will reap bottom line benefits for our customers.”
Focusing on the Driver Experience: Inside and Out
The new Cascadia is loaded with improvements ranging from the layout of the gauges and switches in the driver compartment to features inside the sleeper area, including a new Driver’s Loft configuration.
The original Cascadia is one of the quietest trucks on the road; the new Cascadia is even quieter, thanks to new noise abatement technology. To further improve the truck’s interior sound level, Freightliner engineers have developed an optional insulation package using 3M Thinsulate™ technology. Additionally, a new engine mount design provides better vibration isolation and the engine tunnel cover is now constructed using Quiet Steel® technology.
Delivering Safety
Using a full LED system, the Cascadia’s innovative new headlights incorporate LEDs in the low beam, high beam, daytime running lamp, park lamp and turn signal lamp. The LED provides an impressive field of view in nighttime and bad weather conditions, which enables drivers to better distinguish objects in the road as well as reduce eye strain.
The optional Detroit™ Assurance 4.0 suite of safety systems includes Active Brake Assist that now provides full braking on stationary objects, Adaptive Cruise Control and Lane Departure Warning with optional video capture. This proprietary safety suite includes driver-friendly controls and is seamlessly integrated into the truck’s dashboard, engine and transmission electronics and can enhance driver safety by mitigating collisions.
Detroit Adds Analytics to Suite of Connected Vehicle Services
Heavy Duty Trucking  /  September 1, 2016
Detroit has introduced Detroit Connect Analytics as part of its Detroit Connect suite of connected vehicle services, to give customers “important insights about their vehicles to help them make critical business decisions.”
Analytics will be available through the connectivity platform launching with the next-generation Freightliner Cascadia, which was rolled out on Sept. 1 in Colorado Springs.
Detroit said Analytics, accessed via a dedicated section of the new Detroit Connect portal, will provide users with on-demand automated fuel-efficiency and safety analysis and reports featuring key insights from Detroit and Daimler Trucks North America engineers.
“Analytics uses that expertise to quickly identify behaviors, trends, root causes and key insights on fuel consumption and safety performance data across the fleet,” stated the company.
Detroit said the data provides easy-to-read analysis and recommendations for improving vehicle and fleet performance and fleet managers can view the data for a single trip, single vehicle or their entire fleet over different periods of time.
Fuel-efficiency performance data analyzed includes engine speed, idle time, cruise control, engine power, integrated powertrain performance and driver interaction. The safety data is collected from all available safety systems, including the Detroit Assurance suite of safety systems, and includes collision mitigation braking, lane departure warning, distance violations and speed violations.
“The combination of Detroit Connect Analytics and the new Cascadia enhances the truck’s performance potential by using data to deepen the connection between the fleet’s management, the driver and the vehicle,” said Matt Pfaffenbach, director, connectivity for DTNA.
“The ability to unlock and understand what’s happening with the truck and use that knowledge to make adjustments is a significant time and performance advantage for our customers,” he added. “Customers can spend less time crunching data and more time optimizing vehicle performance.”
The system will be included in different service option packages with the new Cascadia that will deliver the fuel efficiency features only or both fuel efficiency and safety features.
Detroit Connect Analytics will be available for use with the new Cascadia beginning in the first quarter of next year. It will be available with other Freightliner and Western Star models later in 2017.
Click here for more information from Detroit.
Going for optimized aerodynamics inherently affects the vehicles exterior aesthetics. I know all about that. But that said, the exterior of this truck is a dog.
At least, they could have created a spectacular interior. But no. The all-new Scania interior is SO much better, so far ahead of this cheap interior that it isn't even funny.
This is a prime example of the European trucks not only being five years ahead of US market trucks in content, but also in quality of design.
https://www.scania.com/group/en/images/interior-nextgenscania/
Agreed, but by definition it's a fleet truck. And most american fleets are too dumb to figure out that a better truck and better pay would go a long way to ending the "driver shortage" they created!
It's shocking how cheap (decontented) the U.S. truck cabs have become. It's so bad that the next generation cabs from the leading Chinese truckmakers, benchmarking the latest European trucks, will edge past the US trucks.
The Pinnacle/Vision (CH) interior, like the cab itself, is ancient.
Well what strikes me is the attention to the "large car" market with high rise sleepers featured in virtually all of the marketing effort.  Did they notice the Old Dominion day cab tractor in the "big 12" customer base?
I still say between the driver issue and double stack rail improvements, the intermodal business is going to overtake the business at some point in time.
As for the exterior, I have to say, IMO it is much better than the existing Cascadia-and certainly better looking than the Volvo's.  And no doubt, listening to the F'liner "brass", no doubt plenty of "accents" so there has to be a lot of Euro influence in these trucks.
Also, no mention of Cummins, Eaton etc.  Does that mean these products are not on option list?
Bob, I don't see any European influence in the exterior and interior styling cues of this next generation Cascadia. It has no personality inside or out. Though the Actros is designed for superior aerodynamics, it also has attractive styling.
14 hours ago, kscarbel2 said:
Just wondering, how recently have you had an opportunity to drive the latest European tractors?
Kevin,
I would say the issue still remains a preference for conventionals vs. cab overs with a lot of guys.
Then again you have the "new breed".   Case in point, when you can get say the same HP in a cab with say a 106 BBC, why would a guy want one with 119" BBC?  But they do!  Then they obscure forward visibility with a huge sunscreen and drive with the seat on the floor!  I asked one guy one day why he drove with the seat in a low position (you can just see these guys peering over the steering wheel) and he said..."better visibility!"  Duh!
I don't sit on the floor . I do like like the longer hoods as that's what I've grown up with and driven for 18 years long hood macks. I just think the euro cab over designs are ugly they all look the same like over grown refrigerators. I'm sure the drive nice .
8 hours ago, logtruckman said:
I don't sit on the floor. I do like like the longer hoods as that's what I've grown up with and driven for 18 years long hood macks. I just think the euro cab over designs are ugly they all look the same like over grown refrigerators. I'm sure the drive nice .
Back in the day, half the trucks that Mack sold were COEs. Back then, many thought the COEs, the F-model, Cruise-Liner and Ultra-Liner were for the real, professional drivers. Of course, if your COE had the Mack V-8, that nailed it. To each his own, but I'd rather drive a COE over a conventional any day of the week. I can "wear" an F-model like my favorite pair of gloves, whereas the Super-Liner is clumsy with its long nose and wheelbase that kills maneuverability.
If you grew up within the confines of the R/U/DM cab, the F-model cab felt incredibly spacious. And the Cruise-Liner cab, my gosh, if you'd previously driven R-models, felt huge!
I've never understood those drivers who sit on the floor.
I agree, trucking is a business where success goes to the most efficient. Trucking is not much of a lifestyle, as all too many "big riggers' learn from the repo man.
To be efficient, you need to haul as much freight as possible to achieve the lowest per unit cost. For two thirds of the truckers the freight fills up the trailer before reaching the weight limits, so for two thirds of truckers fitting the largest freight carrying bodies possible is a high priority. In most of the world where the overall lengths of trucks are set by law but not so much the cargo carrying portion of the vehicle, for those two thirds of truckers a cabover is the most efficient truck. America is one of the few exceptions with our lack of federal overall length limits, and thusly we're stuck with oddball conventional cab trucks. And because we're not a big enough market to justify four manufacturers keeping their conventional cab products up to date, we're stuck driving antiques.
