  • entries
    101
  • comments
    257
  • views
    49,428
Therapy And An Old Truck
Some time ago I think I posted that I was getting some body hammers and dollies to work out some of the dents in my B-67 cab.
Well after reading everything I could find on the subject, I started in on beating the s---- out of the poor old cab. Wrong.
I have found this metal bumping, as the industry calls it, to be a tremendous therapeutic treatment for stress and anxiety.
Started out wailing away on a dent with the new hammers and dollies - but that approach is useless. It's a little like a Japanese bonsai garden -
careful, consistent hammering and really careful placement of the backing surface (dolly) actually makes the metal behave like butter.
The Zen of Mack beating.
It's not perfect yet, but the cab sure looks a lot better than when I started. And I shouldn't need any more than a very tiny amount of filler, if any.
Way back, when I started in on these old trucks, Tom Gannaway told me that I shouldn't bother with body filler if I didn't change the springs to air ride because it would never stick. I took that to heart. So all of my repairs are welded metal, and now, reshaped original metal. Slow for sure, but I think it's a better way to do things.
And Tom (Other Dog) - the key is the dollies. If you can get them to do the work for you, life is much better.
7 Comments
NoClueJoe66
Posted
On several occasions I used a rubber block for sanding for that kinda work. Anywho, I always wanted to learn how to heat lead and fill small holes in with. Kinda self explanatory, but has to be difficult. Some people have the nack for metal work, I have NONE. I guess dad's truck will be a true test for me considering I've never fully rebuilt a vehicle before. Don't work to hard.....
other dog
Posted
Bob the Builder-what I get for pickin' at Paul I guess
NoClueJoe66
Posted
No, I just thought about it yesterday cause there's this show that comes on called Handy Manny. The boys like watching it and I got the theme song to it stuck in my head.
Bollweevil
Posted
Therapy, I could use some therapy about now, I don't know if it should involve a hammer though. It takes a lot of patience and practice to be able to straighten a body panel with a hammer and dolly. Otherwise whatever you happen to be working on could look like you had added a couple of syrup buckets to the repair. As a young man, I worked at a Buick dealership in Atlanta. I still remember my body repairman friend laughing and shaking his head over a Buick Lesabre that had been hit in the left rear quarter panel. The owner had climbed into the trunk with a claw hammer to work the dent out, and when he had finished it looked like a tow sack full of walnuts. I've already fixed the worse part, he had said before leaving it to be repaired. I am also reminded of something an older fellow once told me. Don't never hit no Harley Davidson with no hammer. Now things are all turned around, and I am the older fellow. Dammit boy, how did this happen?
vanscottbuilders
Posted
Body hammers are a little different than what I ever pictured. They are quite small and light.
The theory is pretty simple. Metal streches when it is dented or bent. Just beating the dent out with a heavy
hammer can't work because you are trying to stuff more material back into the original shape.
The idea is to shrink the metal back to its' original volume. If it's done properly, there will little or no
filler necessary. (In theory that is - I have a long way to go to get to that point)
The therapy part comes with the tapping and studying of the repair, and watching it change as you work.
Sounds mystical - and it might be. You know - "Zen and the Art of Mack Beating" or something like that.
Seriously, it is pretty interesting, at least to me.
And, yes Joe, lead work might indeed be next. All of the old seams and
smoothed areas on a car body were finished with lead before painting. I think there is a real art to lead work,
and I don't know anything about it.
I just think metal bumping is a better way to repair panels rather than plastering on fiberglass filler.
