  • entries
    101
  • comments
    257
  • views
    48,937
Spring Progress
Taught myself some new swear words trying to disassemble and reassemble my B-67 tie rod ends.
They are the adjustable and rebuildable type. But getting the nut out from inside the tube on each one
after fifty years is a lot easier said than done!
Used a four foot pipe on a long breaker bar with a 3/4 drive straight head socket and still had a lot of trouble.
About a quart of penetrating oil and two cans of WD-40 later, I finally had them apart. But I had broken the
socket in the process.
I gathered all brand new replacement parts from Beam Mack and a friend of mine who had NOS rebuild kits.
Now having a tool custom for the job after breaking another socket trying to reassemble the ends.
The rest of the front axle has come together pretty nicely.
New bearings, special sleeved seals, new kingpins, a little remedial machine work, and it's all reassembled.
(Except for the g---***--ed tie rod!!) I'm actually excited about driving it. Should be pretty nice.
Although the B model trucks were the first heavy duty trucks I drove, by the time I was driving them it was early
in the 70's, the trucks were all pretty much used up. Most of them were in pretty rough shape, so I never drove a good one.
Some advice for anyone wanting to rebuild those old adjustable tie-rod ends: Don't bother. Just change to the new replaceable
style unit. You will be much happier in the long run.
0 Comments
