  • entries
    101
  • comments
    257
  • views
    49,460
Progress Report 07/16/09
Moving right along, and spending right along too!!
Anyway - Got the 711 engine out of the old R-600,
and did the transfer of those "few" items that need changing
to fit in the short hood of the B-67. Basically, everything on
the outside of the engine except the exhaust manifold and
the rear section of the air intake has to change.
The engine was steam cleaned and degreased. It got two good
coats of hi-temp enamel tonite, and looks great! I took off all
of the aluminum water manifold and air intake pieces so I could
polish them up.
Bought all new Aeroquip engine hoses and re-useable ends.
They don't give that stuff away!!
Also got new upper and lower engine gasket sets, crank seals,
clutch disc, throw-out bearing and pilot bearing on the way.
Expensive week for the old wallet.
I'm having the flywheel resurfaced, and will see if anyone will tackle re-
surfacing the pressure plate. It looks pretty good, and I'll use it as is,
if they aren't re-surfaceable.
Time to get the radiator checked out and get the transmission covers off
to see if everything's happy inside it.
Moving right along >>>>>>>>>>>>>>
0 Comments
