  • entry
    1
  • comment
    1
  • views
    6,982
Air Hammers Rule!
OK I ask every one to add to this one!!!
My single favorite tool in my shop is the air hammer!!! ( followed closely by the flame wrench)
I figure out a new use for it almost daily..... (feel as if i'm writing a 5th grade essay)
I think between me and everyone else here we should be able to come up with at least 101 uses for the air hammer. (don't forget the safety glassses)
I will number mine as I remember them.....
1. Most common use in my shop is the "hard to get on with a wrench" hydraulic fitting. I can remove virtually any sized hydraulic fitting with an air hammer exclusively.
2. Brake drum removal.
3. Throttle lever (breakover arm) on an ambac v-8 pump on an e-9 injection pump. used that one today to get the bastard back on.
4. rattling a frozen clutch loose for adjustment.
5. removing frame bolts
6. rattling rust loose from a truck frame (before sandblasting)
7. tie rod ends (not using the pickle fork)
8. chipping frozen Manure off the side of my manure tanks (that ones a bit messy)
9. remove a snarled mess of plastic twine string from manure beaters, sharp spade bit for that one. (use it to cut them off)
10. removing bearing races from shafts
11. breaking hard nuts loose.
There is my start to this blog......... I will add to it as i remember them or create new uses please do so also!!
Oh by the way my weapon of choice is a Snap-On ph3050 with quick attach
1 Comment
lndz
Posted
I knew there was someone else with an air hammer. I was probably 25 years of working alone before I got a notion to try a flat nose bit on a hydraulic fitting. Had used hammers before that when I could. But the air hammer is nice! Haven't tried it on the tie rod ends yet but now I have some inspiration, thank you! Guess I should add that I haven't hurt a fitting but you could damage one if you don't think to use a little finese.
On frozen clutch adjusters. I know this will get me in deep do here. I have gotten them hot and sprayed water into the clutch. Engine off and engine on. Banged the pedal several times. It was messy as heck but it worked when nothing else seemed to do. I thought with it hot and the shocking, well it did and the long term was fine. After getting that thing moving I sprayed some PB Blaster in there. I know I am nuts. They are still going.
Liked your words.
