  • entry
    1
  • comments
    15
  • views
    4,496
15 Comments
jaymi
Posted
good day
i am having a challenge with my Mack ch613 2000 model fuel processor 382 it doesn't retain diesel and sometimes it cuts diesel on motion.i have tried to trace the problem but no head way yet.
Xw32131
Posted
is it an e-tech or aset ai/ac???
Rob Reasor
Posted
I have a 1998 CH613 with a trouble code 64, the truck will shut down, the engine will not turn off with the key
Richardb1979
Posted
ive got a 2003 ch613. im trying to find the blower motor relay and the dealership cant help me for some stupid reason.
Joseph Donnelly
Posted
I just bought a 1990 RD688S with the wrong front tires. How do I find out what size tires came on the truck originally?
kazbah
Posted
1 have a 94 mack ms 200p cabover and i cant get the cab to unlatch so i can raise it.
do you have any ideas that might help?
Sebastian Tovar
Posted
necesito el manual técnico electrico y del motor de mack vision CXN613 2005 tengo problemas de encendido
Xw32131
Posted
Anytime you guys need help, you need to send me the last six digits of your VIN
Thanks,
RCG Trucking
Posted
Hi I am new here and am trying to aquire a air piping schematic for a T2180B transmission 18 speed
kazbah
Posted
i have a 1994 mack ms 200 cab over box truck and i cant get the latch to work in order to
raise the cab. it has a sticker on the back of the cab with instructions and i followed them
but the cab wont budge. do you have any ideas? thanks frank
Fernando Bedoya
Posted
Hi.
Check the left door inside. It contains tires recommended.
missjo
Posted
Would you know how to turn up the torque on a 1990 mack superliner?
porkpig1
Posted
hey there I have a 2011 granite gu713 with the mp8 engine. I want to install a oil sampling tap but cant seem to find a blank oil pressure port. any suggestions
vernon1023
Posted
Hello can you tell me what I can check or replace when a Mack truck with this vin# 7M057351. I have a fan clutch that stays on. I check the fan clutch with air pressure it goes off and also check the fan clutch switch. they both work but what do I check next?. please help, thank you
