  • entry
    1
  • comments
    3
  • views
    3,495
air compresson change ?
Hi need help mechanic is busting me , my entire air syst seems to be contaminated with brownish black type of dirtish oil and its cgging my hoses ruining my braks system and the tanks are all contaminated , do I need a new compressor or is a filter ? the mechanic cleaned the air tanks and they were full of this material , and the air systems is constantly getting clugged ... what coud it be I feel the mechanic is cleaning but not fixing my main problem help!1
3 Comments
Mmerse
Posted
Check hose that runs from intake manifold to compressor for oil residue if you do then you might have a bad turbo
slingblade
Posted
weird how dirt is getting in?but it sounds like the compressor is bad,id check the air filter system to make sure its sealed good after the filter element
Para003
Posted
Had a Coolpower that you drained sludge every day from it. Fitters put a new compressor on her and no more sludge ! Hope this helps mate
Chris
