  • entries
    8
  • comments
    6
  • views
    3,633
3 Comments
robert pinto
Posted
currently looking at b model that has an air clutch . i was told they can be troublesome should i stayaway from it. or can they be worked on or easily convert
ed to hydraulic
Posted
ed to hydraulic
Have never seen a B series with an air assist clutch myself. Post some photos of this setup.
Posted
Wondering iF the truck you are looking at has a "Monoshift" transmission? If so it is not an air clutch but rather an air cylinder that operates the rear compound of the transmission. There would be a single shifter with a flipper valve on the stick. The clutch pedal is fully depressed to the floor to allow the air circuit to operate the cylinder shifting the compound. I think those transmissions were trdl-7225.
