r600
Bulldog
Everything posted by r600
  1. your on the ball superdog,does the rst mean anything special its only got 34,000 backend though it maybe light duty???
  2. hey rob,is r686 the same as r685??my engine is endt675 and the built date 1976,thanks(ps hope your feeling better)adrian
  3. can anyone tell me what r685rst stands for??thanks adrian
  4. no, the truck has strong oil presure even when hot!what's the link with oil presure????adrian
  5. DROVE THE TRUCK HOME TONIGHT THAT THROTTLE IS A F#@k OF A THING!NOT BAD ON A GOOD ROAD BUT ON DIRT ITS A SHIT.DID CHECK THE THROTTLE LEVER SPRING, IF I HOLD THE BOTTOM PART OF THE LEVER THAT BOLTS TO THE SHAFT INTO THE PUMP AND MOVE THE TOP HALF OF THE LEVER IT MOVES HEAPS BEFORE IT TAKES UP.??IS IT GOOD OR BAD??WHY HAVE THE LEVER SETUP LIKE THAT???????????????(PS DID I SAY IT DRIVES GOOD A PART FROM THAT THROTTLE) CHEERS AND HELP ADRIAN
  6. can anyone tell me whats the go when i release the maxi's the maxi brake dash valve leaks air.maybe it's a chamber leaking back through the hand valve?if its is do i just remove a air line from the spring brake side when there released an dcheck for air???help,thanks adrian
  7. hey grant did you f-model have full power steering on it?i know you got the box off the valueliner didnt you?cheers adrian
  8. thanks gentleman ,will check it as soon as i get the truck homeand let yoou know what i find,cheers adrian
  9. hi,drove my truck for the first time the other day its r600 237-15 speed road ranger on34-ratio4.64.gets along great after the chassis extension and tailshaft mods not a vibration its great,but when i take off or on coast and try to throttle on a little well dont know how to explain it starts to hop and load the drive line up.carnt tell if its a throttle problem or gear ratio problem.i more to think it a pump problem even when you try to rev up from idle its hard to get it to stay a certain revs or is this what 237 is like.?????help,thanks adrian
  10. r600
    Recap Tires:
    hey rob ,dont forget to measure the outside diameter of the tyres and match up pairs,you may find a lot of difference in outside diameter of the re-caps so matching is a must.(p.s my dad ran re caps on the steer for years with no problem 1st up caps, good cases a must!)cheers adrian
  11. i see a lot of your trucks in the states with super singles on the front of the tippers,does anyone have trouble with king pins due to the off set of the rim???thanks adrian
  12. can anyone help?my r600 doesnt seem to be releasing the brakes properly,seem to be hanging on a little,dont know if i need to be looking at the two relay valves in the chassis or the footvalve?have re-adjusted all the brakes again and its not that ,help????thanks adrian
  13. hey rob and theakerstwo,just looking in some older books here in oz they used rt613 with the large chrome knob with deep reduction and you blokes would know that you can overdrive them by swaping the gears over in the box never done it but had truck dodge d5n with 653gm and rt610 with gears swapped for overdrive ,cheers adrian
  14. hey thermodyne,the smallest fuller you listed was 9 series thats a big box for 3208,here in oz i think we had 6 series,cheers adrian(p.s happy new year to all at bmt)
  15. hey milo,try gleemans for both i know the trim pai do and the air ram to operate shutters,gleemans wrecking heaps of r-model at the moment,cheers adrian(newcastle n.s.w)
  16. can anyone tell what wires go where on delco remy voltage regulator 9000590 -12v 40??????
  17. can anyone tell me if a 12 volt leece-neville 2500jb has inbuilt regulator or external .having trouble with my r600 not charging???thanks adrian
  18. hey joe,its not that hard just takes a little time and a heap of money,cheers adrian
  19. does anyone have a picture of kysor water alarm relay so i can see whats written on it in relation to terminals???mack want $350 for new one and want to make shore its the problem before i buy one,thanks adrian
