r600
Bulldog
Everything posted by r600
  1. can anyone tell me if they have or have heard endt675 without a muffler?how loud without a muffler?want to get my tipping body as close to the cab as possible and want to remove muffler if not to loud without it??thanks adrian
  2. hk i like what ur telling me re-fork remove but the rattles only when engaging the clutch(push the pedal down)thanks to all for your help adrian
  3. can anyone help my r-model clutch rattles when you depress it ,have looked inside inspection hole and carnt see anything wrong.it's roadranger rt915 the only thing i can see is the throw out bearing grease hose is broken and the grease nipple is at the top and you carnt get at it throw out bearing maybe dry???maybe i can remove the two half's of the throw out shaft and remove the fork and spin the bearing and grease????hope someone hasnt fitted clutch plate back to front????help please adrian
  4. need to replace side cover gaskets on my endt675 the front side cover gasket can anyone tell me do i need to remove injector pump to do this front gasket?if i do need to remove the pump can anyone tell me the best way to remove pump thanks adrian
  5. thanks skip i'll use the gasket and check the other things you have talked about.i was over at mack last week and the f-model was parked over at the workshop and the next day it wasnt there???maybe sold 25 grand that big money.the show i havent heard about if you get any pictures i like to see,thanks again skip ,adrian
  6. hey skip,what's the best to use the silastic or the gasket form gleemans i have been getting heaps of stuff from gleemans so that not a drama.does it use oil????havent driven it only off the step deck i put it up with and straight into my shed.have you got that other f-model yet??did it come from mack newcastle???there has been one there for over 12 months???thanks adrian
  7. my endt675 has an oil leak on the fuel pump side seems to be from the side cover bolted to the block .is this common?maybe its got to much crank case pressure??
  8. Yes the bolts are expensive I think and the part no. is 3ax1827 its10.94 plus tax and the harden washer is 35ax144 its 5.37 plus tax prices are australian .not cheap
  9. can anyone tell me how to tell what type of power assist steering my r600 has??has one directional valve ram r/h side and the steering ram l/h side both mounted too the top of the stub axle????? thanks adrian
  10. can anyone tell me how the electronic pyrometer wiring goes???from the gauge/to the turbo?????thanks adrian
  11. thanks james ,have tryed to look at the pai web site but havent signed up maybe i need too thanks anyway adrian
  12. paul here in australia we call it bailey channel but in the states rob has told me you call it glass runner channel.cheers adrian
  13. good to hear from you rod,thanks for the web side ill check it out,cheers adrian
  14. can anyone give me the part number or parts picture of window bailey channel parts for r600?thanks adrian
  15. trent will this work on my 237????????
  16. can anyone tell me what this is?inside the cab l/h side with side circuit breakers, is it low air buzzer???????thanks adrian
  17. thanks hk trucking for the pictures,do the seat belts have mack on them???maybe if barry reads this he may have new ones????thanks again adrian
  18. does anyone have some interior pictures of the inside of r600 around 1976????ALSO CAN ANYONE TELL ME IF IN AUSTRALIA WAS THIS 1976 R600 MADE WITH SEATBELTS ???IF IT WAS WHAT DO THEY LOOK LIKE?????thanks adrian
  19. big thanks to FJH and also rob for all their help, have sorted the problem there was a problem with the earth wire to the pump shorted to earth found it, sorted it, all good.thanks again lads adrian
  20. thanks hk trucking dont seem to have any power when the keys in the on position.many thanks adrian
  21. can anyone tell me on the inside of the fuse box cover inside the truck(r600) there is a???well i dont know what it is has 2 large cables going too it seperate terminals one terminal goes to the first circuit breaker and other goes into harness.has gent on the plastic cover???? thanks adrian
