r600
Bulldog
Everything posted by r600
  1. check for broken centre bolt or bolt's in the middle of the spring pack-check for broken spring eyes or the wrap in the spring pack,also check stoppers on the stub axle as mentioned before if you do adjust keep in mind that on full lock there is a little mechanical advantage when the steering box is at full lock and truck is moving,if you adjust without engine running and lock them up and put on the ground and roll forward you will find you get a little extra ,also check tie rod ends and drag link ends
  2. rob and trent my truck is 1976 and it has the same latch as trents truck?????
  3. wasnt working now i have sorted wiring out it was soon as you turned dynatard on it was coming on then i removed wire off injector pump and now it wont do anything but if i earth it too the pump it works?how do you adjust the sender ?thanks adrian
  4. can anyone help someone told me the injector pump switch is adjustable is this true?also still having problems with the wiring can any help the relay in wired as follows terminal 30 power all the time-86 or 85 can be the earth or power from switch-87 power to dynatard.i have the earth off the relay going too injector pump??????is this correct
  5. CAN ANYONE GIVE ME MACKS PAINT CODE FOR R600 THE BEIGE IN THE DOOR JAMS.MAXIDYNE237 GAVE ME PPG CODE 23789 BUT MY LOCAL PAINT MAN CARNT MATCH THIS NUMBER.THANKS ADRIAN
  6. rob,my dynatard relay has 4 terminals can you tell me where on your truck they go(tell me if i am right-30 positive power all the time /86 power from dash switch/85 earth to fuel pump/87 to dynatard sol?)thanks adrian
  7. BIG THANKS TOO BOTH NOID93 AND ALSO HK TRUCKING i have got them working.run new power to dash switch and they work. hk trucking is there anyway buy looking at the rocker covers to tell if dynatard or jake?i think it is a dynatard just someone has fit clutch switch(i know no point) . it doesnt sound like jake brakes?????does the terminal on the rocker cover have power all the time waiting for the no fuel signal????thanks adrian
  8. can anyone help with problems i am having with my dynatard.it's need worked since i have owned it .i know the solenoid's are earth to work (i think).i bridged the clutch micro switch(didn't know if it was working properly)i have no power at dash toggle switch(dont know if it works on earth?)maybe its a relay inside cab where all the fuses are can anyone help?thanks adrian
  9. if you have wiring diagram glen that would be great
  10. can anyone tell me how electrically the turn signal switch works.wiring from turn signal switch to flasher can(x2) to blinker lights.help please adrian
  11. thanks for the information great picture thanks again adrian
  12. can anyone tell me where the diff ratio tag is on my r600 with 34,000 mack backend please thanks adrian
  13. nice set of pictures can you please tell why in the states do you guys have long wheelbase with your trailer(no weight over steer axle) and on your ridged units you have tag axle in front of drive axles?what weights can you get on them?here in australia ridged with bogie axle max 22,500 tonne and with trailer bogie on triaxle trailer 42,500 tonnes.adrian
  14. great to have a girl here.your pictures of the rig look ggggreat keep up the pictures cheers from down under
  15. can anyone help me i dont know alot about macks,i have r685rst with endtb675 in it what colour dogs should i have on my doors gold or silver ?what's gold for-what'silver for?thanks
  16. does anyone have a wiring diagram they can e-mail me to suit r-600?thanks
  17. thanks again terry i will do this and let you know how i go
  18. thanks terry,how do you cut them just in a drop saw?thanks again
  19. can anyone give me part numbers for the rubber bush's to suit 34,000 pound backkend bushs,the red bush's that i have had problems with are 7 1/2 inch's but my mack parts man is telling me the rubber bushs only come in 6 5/8 and 8 1/4 ?
  20. thanks for all your comments.i have got new trunnion caps on the way and think i will change the red bush's to rubber. my parts man has told me the bush's only come in 8 1/4 or 6 5/8 but my red bush's are 7 1/2???can anyone help with the right bush maybe a part number . thanks again
  21. can anyone help?i am doing rear trunnion bush's 34,000 backend its got the red bushes when i did them up the lower trunnion half cap broke.i have been told the red bushs are no good to hard?help
  22. thanks will let you know when i have done
  23. does anyone know the paint code for the cream inside the doors of r-model?
