R.E.D
Bulldog
Everything posted by R.E.D
  1. R.E.D
    Trump rally
    I was told as well that they stock mack parts , specially for common gear ratios like 4.17 and 4.42.i have 4.42 so I was in luck...
  2. R.E.D
    Trump rally
    Back one...I did the front one end of June 2021... Thursday I finished my day at around 5pm.yesterday morning took it off and had it rebuilt by 430pm...put it on today.. Houston has a truck hub, off mcarty street.. endless Miles of anything semi truck related.. including 4 or 5 gear train rebuilders..they work fast ...work has warranty as well so they work with diligence in order not to have warranty returns.
  3. R.E.D
    Trump rally
    Yessir..I'm only 19 miles away from the rally..but yesterday the rear end had a ticking sound.. brought it in to get completely rebuilt..it was about time anyway..got it in today afternoon.too late to make it ...tons of people
  4. Trump is in my neck of the woods tonight.couldnt make to the rally because I just got done putting the rear end in the granite..it's live on YouTube right now...
  5. One last thing, this kit fits all mack Carriers?my truck is 2004 year model.
  6. I pump untill new grease shows , except scams, because as mechaulic suggested they fill , the brake shoe with grease and could create unwanted problems.
  7. Yes sir, that's why I favor them ,the stop and go abuse wears them out.
  8. Thank you sir..Euclid is what I bought in the past. Just couldn't remember.
  9. My s cam bushings are shot..I plan on doing an rear end complete overhaul pretty soon..I go to the mack dealer for an unrelated part and ask for a quote for all the brake components for the two drive axles.i ask for the metal s cam bushings not the plastic..guy at the counter says he has never heard of metal s cam bushings..and he has been working for mack for 14years...I didn't want to sit there and argue with the guy so I played dumb and got my part and left...but I remember I installed brass or bronze s cam bushings on my Rd before .does anyone have the part number for the bronze bushings?crd92 93 I believe.. thanks Red
  10. When you replaced clutch, did you take the flywheel to get resurfaced?if so , did you make sure you got your flywheel back and not someone else's? Also I could have sworn there was some post here or service bulletins about the depth of those sensors , and shims.. someone correct me if I'm wrong.
  11. #1 and #6 are on the same Tdc stroke,just something to note
  12. I'm not to educated on mp engines but if they are like any other diesel engine, I would assume that a cylinder balance or contribution test with failed compression will cause the engine to speed up where the compression stroke happens in the dead cylinder , it's an audible speed change when cranking.did you test compression with a known good analog gauge or just electronically?
  13. And check back lash as well.
  14. Search your local Craig's list under services , and look for a heavy diesel mechanic.they most likely will have diagnostics equipment and will be able to help you.
  15. I second that price range..with cash in hand you could get it mid to high 20s.that company probably paid around 15k to 20k for that truck if that..cash is king. Here in houston, there are about 10 to 15 dump truck outfitters churning out dump trucks non stop....these old work horses are not as desirable as they are up north , but I wouldn't trade any of those road queens for that combination of gear train in that rd690.
  16. If you do decide to pull the trigger on it...I always recommend people to take someone that has a scan tool that can read for stored codes in the computer and tell you actual ecm miles.Those analog hour meter and odometer can be newer that the truck ..as they don't reflect the ecm mileage like the digital ones do...not to mention all the shady shenanigans people come up with to make an older truck seem newer...if you really like it , then paying 150$ to 250$ for someone to scan and tell you what's what, ain't that bad...
  17. Many of us share your thoughts Joey ๐Ÿ‘
  18. Hopefully all these comments serve you as ammunition to bring down the price.good luck buddy.
  19. Like onyx said , at least one wheel seal is gone, cylinder on the bed needs repacking soon but will last the way it is, just gotta check hydraulic fluid so you don't burn up your pump..also missing the dummy light in the dash above the tach and speedo...can't remember if it's the parking light or the lightning โšก bolt.lol...nice truck other wise..also they installed a new floor on top of the old one on the bed..you can tell because the bed is wavy looking at it from the bottom but looks new looking at it from the inside..it's not bad just makes the truck a bit heavier. Red
  20. My cousin has the same spec truck as in the add...does the job well with superb mpg , just slower lol Red
  21. I agree with macks ,the learning curve is to steep ..this is the front end we are talking about.something comes loose going down the road because of a error on your part and the results could be catastrophic..this is a dump truck we are talking about ,which carries the load , not pulls it..stubby one inch impact is the way to go...but that's just my .02ยข...if your not tooled up to do it , just have someone else take care of it... besides the one inch impact , we use some 25 ton jacks , pry bars and engine driven air compressor big enough to provide the cfm for the impact to work like it should.let us know. Red
  22. We just take spring pack and have the shop press the bushings in..3 spring should be enough for a tandem truck grossing less than 50k pounds I believe.we use 4 springs ,since the trucks are tri axles and run gross around 55k to 57k pounds .
  23. I'm afraid that 1/2 drive won't be enough..u bolts are one time use since they stretch and the nuts on them pretty much weld themselves in with rust and road grime over time..we use a torch or cut off whel to cut them. You can take them to your local springs shop or big truck parts store to be measured..while your there ,pick up a spring center bolt.this is the bolt that keeps the whole spring pack together..it's doweled at the bottom to center springs pack into the axle..we use a one inch drive impact with short anvil to tighten the u bolts.. tighten evenly and don't forget to put back the wedge...that's what sets your caster .let us know. Red Ps: there's a channel on YouTube called "semi working"..he does this for a living and has a videos on macks too.good luck.
  24. Sir ,what you are describing in my opinion are the bushings as you have suggested.our 2 mack chs have this problem.since they were over the road and since converted to dump truck the rubber bushings don't hold up.. usually we can get a year out of them.they are not greasable ,either in the front or the back at the spring hanger.They noise is most easily heard when turning loaded.see if upgraded polyurethane bushings are available in your area.. polyurethane usually last longer.. picture above from onyx is from an axle that has threaded pins and are greasable...and a later year model to yours ..indicated by the 3 holes on the pin,which I believe is a Volvo design. Red.
  25. Ezra , aka ezrider359 did an amazing job on that old Pete. Phillip from the flannel Phillip YT channel also did it to his old kw w900.but fortunately yours looks good ๐Ÿ‘ and can be brought back with blasting, painting and a little bit of tlc. Red
ร—
ร—
