R.E.D
Bulldog
Everything posted by R.E.D
  1. Merry Christmas!
  2. We are going to need a bit more detail.Year and model engine?how long is white smoke lasting?vmac 2 with electronic injection pumps smoked on start up until oil pressure got to the econovance, which usually took a few seconds.lets us know
  3. I thought I would give everyone an update on how the truck is progressing. Being a quint axle dump truck grossing 72000lbs , I was averaging 4.3 mpg with the s400 turbo and higher flow exhaust manifold.then replaced two unit pumps that were bad, mpg went up to 4.70 mpg, finally I installed the 427/460 injectors and mpg went up to around 5mpg.These numbers have been very consistent for almost a month now..all that is left is 427hp update, I already have a efile ready to go with mack, but since there is so much work now, I can't be down one truck.Truck definitely has more power and requires less downshift ,but then I again power wasn't my main goal..I'm after the mpg, that's what's putting money back in my pocket , come on!! Thanks R.E.D You all have a blessed Sunday.
  4. Exhaust valve push rod has a spring.needs to be compressed when taking measurement and when adjusting as well.
  5. Man that's a double whammy..must be one of the last non etech engines of 98 and one of the last mechanicals of that same year.😅
  6. Here's my set up..cap fits inside intercooler boot.put clamp back on ,not too tight , then apply shop air, don't put too much pressure as you could damage your intercooler, 20psi should suffice.let us know. Red Ps: I couldn't find my 1/4 npt tap so I just heated the fitting with a torch and made the threads that way.then put a nut in the inside for safe measure.😅
  7. It will build some pressure but engine fan will blow the bubbles off.the way I test the intercooler is by capping both sides off with plumbing pvc caps..one of the caps drilled and tapped for 1/4 inch npt fitting..then apply some pressure and soapy water.
  8. If it is the incorrect turbo that someone put on prior to you owning the truck, then most likely would explain the lag
  9. That's a s400 turbo, I believe that turbo was for 400hp+ engines .but someone here can check it for sure if you provide the last six of vin.
  10. Does the lightning bolt come on when the key is put in the on position ,then turns off after a few seconds? The reason I'm asking is because the bulb could be burnt out? Have you checked for boost leaks? They can be heard easier with both windows down going down the road.
  11. I believe that truck should have a s300 turbo. Have you replaced fuel filters ?any fault codes ? lightning ⚡ bolt on?
  12. Here are some cross references for posterity. PAI ECV-8541 to MACK 700GC120 PAI EGA-0461 to MACK 56AX393
  13. Yes.indeed found the parts online and all can be had for around 200$ .. haven't checked with mack.
  14. Thank you and all who commented. Red
  15. Last six are 014602 Cv713 2004
  16. Thanks .. Don't forget old macktechnician.😅
  17. Thank you all for your support and prompt advice.
  18. So is this mount I'm inquiring about a factory option?the pic shows an ami or ai motor ?was this in case people decided to run other coolants besides extended life coolant? Red
  19. mack dealership mark ups are legendary...the other day I went in to get a filters for an oil change.i was feeling lazy so I decided to buy the oil there as well (rotella t4 is what I always use) .I knew there would be a price mark up but not as high as I payed.i usually pay around 13$ to 14$ a Gallon at Walmart or home Depot. when I saw my invoice from mack they charged 26$ a gallon..THATS CRAZY...I was already down the road a bit , yet I had the slight hesitation of turning my pick up around and returning them..I could understand a part can be marked up because it's dealership only or special order or what not..but regular engine oil that can be had anywhere? that's just bonkers what they expect people to pay.
  20. All 3 or 4 mack dealerships Houston are Vanguard trucks.same employees who swap locations all the time.they caught on to people asking for part numbers and just going somewhere else to buy pai
  21. What I'm really hoping to accomplish is to catch any debris or precipitated old coolant that might be in the system.I have owned the truck for 3 years yet I'm not sure how it was treated by the previous owner.
  22. You are right.but won't stop small debris from getting in the cooling system from what could be negligent driver error from putting the coolant cap down somewhere or adding water to make the right mix..in my opinion a filter would add a second barrier of protection..but I might be wrong...just my .02 cents Red
  23. No such thing in my area.they keep part numbers more secret than the coca cola formula
  24. My cv713 did not come equipped from factory with a coolant filter .I would like to add one.attached is a picture of a truck that has the mount for the coolant filter , mine has two npt plugs in its place.Does someone have the part number for the coolant filter mount?or is just better to install a generic one from Amazon or eBay that mounts to engine or chassis.thanks Red
  25. One thing I did notice is that my MPG went up by .5 miles per gallon.and the power is more constant throughout the RPM range.
