ducky698
Pedigreed Bulldog
Everything posted by ducky698
  1. hi, this is hfb 70 on an ozy mack. regards Grant
  2. Hi, do you know who owned it new? wouldnt surprise me if it was Brambles red, Geof may be able to shed some light?? Grant
  3. Hi, welcome, this is a great board, you will enjoy it. regards Grant, Perth, Western Australia
  4. Hi, there still available from Mack. regards Grant
  5. Hello, thank you. thats expensive, am going to try make one at the moment, think i have figured it out?? I need to relocate wiper motor and run an extra pivot point and can then use a wiper motor from a ford falcon 98 model, will get pics up when sorted. Grant
  6. Hi, i see. i have only ever seen spiders or just ten stud here, spiders are more common out here on trailers going north, they tend to keep dollys and trailers the same for going north and carry a couple of spares per trailer, prime movers tend to be either. Grant
  7. Hi, what do you mean inner nuts/ outer nuts? how many nuts hold the 2 wheels on over there? 10 or 20? Im confused :)both inner and outer rim here is held on with ten nuts only, and there under alot of load when dragging 3x 45 ton trailers. Grant
  8. Hi, is there an electric wiper conversion available for an R model? regards Grant
  9. Hi, i see, thats a valueliner here. its the same as the truck my cab and steering box came off, I had the drag link cut down to fit my axle. dual air cleaners will set thing off. regards Grant
  10. hi, its come up well. made from 4mm steel, the holes were plasma cut, all in all about 3 hours work. just put more pics up of the build, am half way thru making rear crossmember at the moment and still working out where to fit that big air tank.Grant
  11. an RB? which model is this? I make a left bracket for an R model air cleaner, I am putting two on mine. Grant
  12. Hello, i havent checked the litres, the one that sits on outside, thats 227Litres is it? pic attached of this one, its come from a ch Grant
  13. Hi, this is a proper cf starter tank that goes undernieth, will snap a pic today, I have all the brackets, but nothing seems to fit any where, have pulled all the brackets off it now and will have a go fitting it up there, it sits close to tail shaft tho. Grant
