Geoff Weeks
Pedigreed Bulldog
  1. After flushing as best you can, install a coolant filter if the engine doesn't have one. Flushing gets the loose stuff out, the filter removes the stuff that wouldn't come loose at flush time, when it does come loose and starts circulating.
  2. Yes, the brushes are outboard of the rear bearing. While not as common as inboard, there are still some in use today that are like that. The Prestolite series comes to mind. They tend to be units that have ball bearings for the rear bearing. Ones with needle bearings that ride on the shaft have inboard slip rings. Brushed go in holders like this that screw into the rear housing .
  3. In this case the internet is quoting the regs, both federal and state. So far you have not provided anything that shows they were cited for "caps on a steer", just hearsay that it happened. You can look up the CFR and the NJ code for yourself. In both cases the exact regulation has been provided.
  4. https://www.traction.com/en/p/a-c-heater-mack-unit-grey-mei10-9725
  5. Some discharge vents are available for Air Source not sure the same ones that used. I thought you were looking for things like blower, Tx valve, drier and the like to get what you have there working. As far as grill-densor's they don't work very well with R 134a, you would be better served with a modern parallel flow type when running R134a R 134a needs a lot of surface area in the condenser, so many small tubes is better then larger widely spaced tubes. as far as "cabinet" pieces, then no I don't know where to locate new. Universal vent covers can be had by the size of the hole. No idea what the "key hole" opening was for. Red Dot still make replacement systems, or did when my Catalog came out. #10-9725 for gray #10-9726 for black
  6. quick look shows Evans Kysor Red Dot and Signett all made units for the R series. You'll likely need to know which you have for some of the parts.
  7. What parts do you need? Most everything should be available from MEI-Airsource.
  8. better picture of the bearing bore:
  9. My thoughts also, but two of the bearings at least have the same ID so it should be as "simple" as removing the slip-rings and replacing the bearing. I say simple, because I wouldn't attempt without slip-ring replacements being on hand. I think I have found those as well.
  10. Since this post got a fire under my butt to finish off the 95 amp 7 volt unit I have. I found out Leese Neville made a "factor update" kit to put silicon diodes in the older units. Made to update the selenium rectifier units. I found one N.O.S. that I have coming, should be here Monday and I'll try to remember to take pictures. From what I could see of it, you get a new rear housing and a cover with the diodes, you remove the three phase taps and replace with a similar terminal block with +, field, and - being the output and input. I'm not entirely sure it will be a direct fit to mine, as I guess, the style alternator could have 3 different rear bearings and this kit fits only one. I am sure there will be a way to either swap bearings or adapt to use the bearing I have. It said 6 volt to 95 amp (mine is rated at this I think) and 12 volt to 65 amp. Not sure why that would be, as most diodes only care about current and PIV. Cost way more than doing it yourself, and not worth the cost on a practical matter, but will be going on a "period" truck and I didn't want it to look "hacked".
  11. I went the other way and had a rim from 1947 on my '83 cabover for a while. If it was sound, I ran it. I've seen some much newer rims I wouldn't touch.
  12. It is very common misconception, and one reason I avoided running caps on steer, because the confusion extends to some DOT inspectors. I at one time, had a paper that addressed that for inspectors that I carried with the truck. Police can write a ticket for anything, that doesn't make it true or correct! To be honest, I only had caps on the steer for one trip. The new steer tires didn't come in and I had to make a run. Took it from the midwest to the west coast and back with caps on the steer. When I got back the new steer tire had come in the the caps were rotated to the drives. The caps in the above tread design came in two depths, one for trailer shallow, and one for all other positions. Mine were "deep" tread.
  13. My bad, I forgot I changed capper, when I moved Michelin XZE tread. Tire is a 10Rx20
  14. You can get caps in many tread designs. I used to get them in "goodyear 159" type rib tread, that I ran in all positions. I didn't run "lugs" on the drives. If I remember I'll take a picture on the brand new caps on the rear of my Marmon with 0 miles. The weight limit on re-grooved only applied to steer position. Drive and trailer could be used to the full weight rating of the tire. Re grooved on steering is limited to somewhere around 4K lbs (I don't remember the exact figure) but for just about all purposes, a re-grooveable tire, would fall above that limit when on a steer axle. I guess maybe my K front axle is under that empty, not sure loaded. The "Pumpkin" likely was putting them on trailers, where they could take 6K each tire.
  15. I find that very hard to believe! Show me in writing where your insurance company says that! J.C. has posted the federal regs straight from the book, N.J. couldn't have restrictions that the feds don't and receive hiway funds. It is why STAA rules are in place that standardize loads and equipment nation wide for trucks. Regrooved tires is another story. they are illegal over a set weight. Show me the citation or it is just another truckers story! "I heard" but didn't happen to me". There are plenty of reasons why a truck could be "downed" and need things changed on the front axle, and I can see a guy not wanting to admit to poor maintenance and make up a story about caps, but I would have to see it in writing to believe it. It is also possible the inspector doesn't know his job, but that should be sorted out in court.
  16. Paul, I would order those tires you posted. The Mfg own website lists them as TT or tube type.
  17. If you look at the regulation in the "green book" or the stuff J.C posted doesn't make a distinction between school buses and other buses. In my Green Book of the Federal Regulation, it uses the term "Passenger Carrying Vehicle.
  18. Not exactly, the spokes force the rim out and that is countered by the solid lock ring, holding it from expanding. To dismount, you have to remove deflate (or deflate and remove) break the bead, place on a block near the split, then you put a rim tool into the slot, and pry the rim in under itself, pealing it away from the tire. When mounting, the safest is to air up after mounting to the spoke, the spoke will expand the rim, bringing the ends into alignment and holding until air pressure can hold it. I have a bunch on my K's, I still prefer split lock ring style, but I restored a bunch and mounted tires on. It was hard to find lock-ring style in narrow enough width.
  19. That is an extremely common one and many police inspectors get it wrong. It was something at the CVSA class the instructor harped on. It only applies to buses. The old Goodyear rim that splits along the valve stem slot is another rim that most young inspectors get wrong. The claim the rim is cracked all the way through! Ok, what is holding then?
  20. I have many "tire shops" say multi-piece rims are "Illegal" I always correct them, They are not Illegal, you may refuse to work on if you chose, but that isn't the same thing, Be honest about what you are doing. Not even the Firestone RH 5 deg (widowmaker) is illegal, it and all multi-piece rims/wheels were "recommended" to be made Illegal by the Insurance Institute, and insurance trade group, but they have no standing to make law. The Firestone is the only one I don't like to do. There is no good way to be sure it is going to stay together after all these years. The way they latch together is also where the most rust and weakening takes place.
  21. Heard that also, I just laugh at them,
  22. I've even heard people say "Spokes on the steer are illegal"!
  23. Re grooving went away, because once you re-groove you can't re-cap. Cap gets more extra miles out of the casing than you'll get re-grooving. also re grooved are not allowed on steers, caps are (trucks not buses)
  24. wondering how you ever made out with your tire dilemma?
