Content Type
Profiles
Forums
Gallery
Events
Blogs
BMT Wiki
Collections
Store
Everything posted by Deere Mack
Lighting bolt and check trans light on
Deere Mack replied to Madmixer's topic in Modern Mack Truck General Discussion
My 17 granite had an similar issue with the Allison. It was a bad wiring harness from the dash to the trans. It was pinched and took a while to rub through and short out. -
1996 E7-427 exhaust noise and high pyro
Deere Mack replied to Deere Mack's topic in Engine and Transmission
Good morning and thanks for tip. I did a visual on that hose and didn't notice anything, but it might take some pressure before that would show up? -
when I took it on the last drive, I took my father in law. He's not much of an mechanic but a retired over the road trucker. He thinks it's an injector. I'm not sure now because it's worse with an overall loss of power and it seemed to have an rough idle that kind comes and goes. Pyro is still quick to hit 900 especially in higher gears and I'm sure if I were loaded it would climb back to the 1200 mark. I have checked for leaks with soapy water but I did not pull the codes or boost. I will this morning. The noise it's making sounds like a blown exhaust gasket to me, but it's not, no exhaust or intake leaks at all. -
took her for a spin after going over a few more things and still have the problem with a lightning bolt on the dash now ⚡ kachow! -
Thanks, good to hear from you! No I don't. Could this make the "exhaust leak" noise? What part of the Jake do you think is failing, just sticking, solenoid? -
Hello everyone, it's been a while. I hope everyone's doing well. My 1996 CH613 E7-427 started out making a noise that sounded like a bad exhaust leak, then in a good pull the pyro would jump up to 1200+/- quickly and running at around 900 but will drop on down at idle. No noticeable lose in power but I was paying more attention to the noise before I parked it. Can't seem to find any leaks and was wondering about the engine brake? Anyone have any input?
Noisy PTO rattle with MP8's and Allison Auto
Good morning, hope everyone had an awesome 4th of July. I did remove the cable and put in air for the hoist control and for the record, my truck is a 100 times more quiet than before. None of the sound is traveling directly inside the cab now. The rattle is still there but it's totally different and no where near as noticeable. Anyone who has experienced this probably understands when I say the sound varies, so at times now I cant hear it at all. The air control is different but I'm perfectly fine with it. I've hauled chert and gravel spread with no problems at all. The only noticeable difference for me was mine doesn't automatically jump out of the raise position when the bed is all the way up. I appreciate everyone's input. And for those who told me to get used to it, get a loader radio, thanks for nothing. lol I hope this will help someone out and give them a more peaceful ride like it did for me. -
Good morning, I appreciate your suggestion. I've tried putting rubber everywhere imaginable. Put rubber o rings in between the pin connection at cable and PTO, thick rubber on and around the cable bracket and in between cable and bracket. I also put extra sound deadening material on the inside of my control tower. I've been desperate to eliminate this problem. lol I think the only way to help with the cable would be to have some type of plastic connection between PTO and cable. Even then sound travels through hard plastic fairly well. Installing air shift next week with polyethylene lines, the quietest way to go. -
Looks like I might make the change, got to see if it makes a difference. Anyone that has one as loud as mine will understand and hopefully it'll work and help out some other guy down the road. The air operated hoist control is new to me, I've always had the cable. Is there anything I should know or look for, or is it a just a bad idea for a tri axle dump truck? Any info would be a help. Thanks -
If he wants to test it out for himself it will take about 15min to remove the cable completely from the pto & pump, even the line from the bracket so no part of the cable is touching. He'll be amazed, I swear it was like I was in a different truck. -
I'm sure there's a lot to consider, brand, install etc. But I'd be very interested in hearing from someone with the MP8 and Allison auto with the air control. -
It's the control cable for the hoist up & down. My PTO is air operated. It may be a trade off, feathering capabilities or extremely loud jack hammer sound in cab. Don't forget I understand these trucks are known for the PTO rattle with the Allison auto. But the discovery is that it enters the cab through the Hoist control cable. Remove the cable from the PTO and Bracket, tie it away and no more noise. The only way you'll here it is to roll down your window and hang your head out the cab. If anyone out there has my setup with air operated hoist control please chime in. Thanks! -
The information below shows how sound travels through different mediums. Make notice to steel vs Nylon or Polyethylene. Most air lines are made of nylon or polyethylene and even between the two of those there's a considerable difference. Looks like the polyethylene line wins my vote. Mild Steel 3235 m/s Nylon 1150 m/s Polyethylene 540 m/s Dry Air (can vary depending on humidity) 346 m/s So the totals are a poly line with air would be 886 m/s vs a steel cable with nylon sheath 4385 m/s. The math says the air control hoist valve vs a cable control should be a lot quieter. 🤔 -
I appreciate the information Rob. I've got a good feeling about it all. Been digging in on air control valves and looking at options. If you don't mind me asking, do you remember roughly the cost of converting? -
Need to talk with a noise and vibration expert. -
I feel like it would make a difference but not sure. I wonder if the air lines could act like fiber optic cables and carry the sound or if it's mainly the vibration from the metal cable carrying the noise. Anyone out there have the same set up with air controls? -
I wonder if the air control valves would work. Not sure if sound would travel up an air line the same way. -
Hello everyone, I've talked to a few of you before about this problem. I bought a 2017 GU713 MP8 Allison auto dump truck at the end of last year. The problem I had was the PTO rattle being very loud inside the truck. My dealer had made several attempts to quieten it with no luck. I know now this is a known issue but today I hit major discovery. Every bit of the sound I was hearing was traveling up my shift or raise/lower cable. The sound is traveling up the cable like a speaker wire and blasting out of my control console. I remove the cable from the PTO completely, bracket too and no noise what so ever...NONE! So now, how do I fix this? I'd love to hear some ideas. My first thought would be convert to a electronic or air system and eliminate the cable, but I'm not sure whats out there.
New Engine or New Truck?
Deere Mack replied to Deere Mack's topic in Modern Mack Truck General Discussion
I knew someone would get a kick out of that. Talked with the owner, he has plans of an mild restoration. It sure sounded good.. -
Lets hope so! Loving the automatic, but that PTO rattle is driving me crazy! -
Well, after an intense search and coming up with mostly used and abused, I just went for the new truck. Talked myself into it. So far it's been in the shop three times: On delivery day, did inspection, power divider wouldn't lock (wasn't even hooked up) and had a bad air leak at tank. Back to shop, fixed. Got an Allison auto and it started acting up, not shifting properly and throwing codes. Ends up the wiring harness from dash to trans was damaged during the truck build. Back to shop fixed. Discovered rear drive pinion seal was leaking. Went to fix and discovered bad threads on pinion gear, replaced with new pinion gear and seal. Not even 2600 miles. Someone please tell me it gets better...lol -
Allison HD and Mack Mdrive information
Hello, we are in negotiations and I had rather not disclose that information publicly. Plus I've talked with dealers across the lines. If there's something you can help me with or need to tell me, feel free to message me. -
Hello, looking at the new tri-axle Granite dump trucks and researching the new transmissions available. Looking for user experiences. I've talked with local drivers who said the only thing they didn't like about the earlier auto's (pre 2016?) is down hill backing. I was told there was no help from the Allison, brakes only. I've read where the new Mdrive has multiple reverse gears which would help but I can't find anything saying the same for the Allison. I appreciate everyone's feedback. thanks!
Yes, said it was a County Truck.
BigMackTrucks.com
Our Vendors and Advertisers
