A client of mine has just imported from the States a 1960 Mack, Model B85.
I have been asked to check out the starting fault and found the truck to be a 12v system and positive earth, can someone tell me if this is standard? or have the batteries been fitted incorrectly?
The truck is fitted with a petrol / gas motor and set up as a fire engine.
any help would be greatly appreciated.
Harry
https://www.bigmacktrucks.com/topic/10188-1960-mack-model-b85/
Harry
Being a gasoline, (petrol) powered unit this would be correct. Positive ground, (earth) was very common in the timeframe before alternators became the normal application for battery charging.
https://www.bigmacktrucks.com/topic/10188-1960-mack-model-b85/#findComment-38598
My 65 B75 was positive ground also.
Russ
https://www.bigmacktrucks.com/topic/10188-1960-mack-model-b85/#findComment-38622
