Personaly i think the 250 is weak. I can feel the diffrence in HP between a 250 and 300 and if its a low RPM 250 motor its even worse!
it will do the job but I dont think you would like the change in HP... Find out if your 300 pump will fit the 250 and just have it timed and swap some parts to get it up to a 300HP
https://www.bigmacktrucks.com/topic/10237-engine-info/#findComment-38745
Thanks for the advice Lmackattack. I've never driven a 250 E6 and did know what to expect. I'll check with mack and see if the components will swap to get a 300 out of this block. Thanks again
https://www.bigmacktrucks.com/topic/10237-engine-info/#findComment-38752
  • 1 month later...
