anyone out their know where to purchase new wheel cyls for a 54 mack ls85 fire truck ,it has 2 cyl per wheel . thanks
You are going to need to know which axle, and brake setup your truck has installed. A competent counter person at either a Napa, or Carquest store could be good leads but as a last resort they can be sleeved to use standard and routinely available cups. It really is not that expensive the have performed. Look up whitepostrestorations.com for one vendor. They are probably the most expensive for a guide if you don't use them.
thanks for the info rob, I just got the build sheets from the mack museum ,so that should help, the key is finding a good counter person like you said . I used whitepost before to rebuild a master cyl and hydrovac unit on a 47 mack I have.
thanks Al
