Theres a dead short circuit somewhere between the dash switch & the jakes, or possibly internally in the jake brake. Try disconnecting the wire from 1 jake at a time & turn on the switch, see which one either does or does not blow the fuse, also try disconnecting wires from both jakes & turn on the switch, if the fuse still blows then the problem is in the wiring between the dash & the jakes or in the switch on the pump. If it turns out that 1 jake is shorted internally, pull that valve cover & check for a pinched wire in there between the jake spacer & the jake brake unit, if that checks out then the problem is in the jake unit itself. BTW, a jake brake should also have a switch on the clutch pedal to shut off the jake when the clutch is disengaged.
https://www.bigmacktrucks.com/topic/1040-help-with-a-jake/#findComment-5328
