Albert,
Are you talking about the Pressure Volume transfer valve? Is the valve operator using engine vacuum? If so you also have a manual lever under the pump that operates the valve. Try to operate it manully. You should have a QL75 hale pump, I can check the diagram and let you know if there is any lubrication point for the valve.
Firemack
https://www.bigmacktrucks.com/topic/10493-transfer-valve/#findComment-39789
Albert,
Firemack
https://www.bigmacktrucks.com/topic/10493-transfer-valve/#findComment-39805
thanks for reply, their is no vaccum unit , the transfer valve is manually operated, the control rod goes through the pump panel to 2 gears that rotate a diverter inside the pump casting , you can only move the knob a half turn , have another mack and the knob goes 3.5 turns to complete the operation of pressure to volumn or visa/versa. thanks, AL
https://www.bigmacktrucks.com/topic/10493-transfer-valve/#findComment-39806
