we have a 1971 mack cf600 fire truck engine is a cf685f and the transmission went need to find either the parts or new/rebuilt transmission we dont know what the model # is on the transmission
From memory it should be a TR-107 if direct in hi gear, and a TR-1070 if overdrive. The numbers will be hand stamped into a flat pad in the side of the transmission case on the driver's side and they will be about 5/16ths inch tall.
thank you fyi was very helpful i now know the trans is a tr107 thank yoy again Rob.
You're quite welcome.
  • 3 weeks later...
  • 6 months later...
transmission repair: i was wrong about the trans being a tr107 . I cralled my butt and looked at the location where i believe rob said to search and lo and behold the trans is a r700. sorry about the mis information, but thank you for the information and input that was posted.
