In need of a flywheel for a mack motor 17 1/2 in. 138 tooth mack part #530GB4275, OLD #1286 ANYBODY ?
A dished flywheel will use a 14" clutch and was most common. A flat flywheel will use a 15" and was very heavy duty in those years. Either way the weight is going to be expensive to ship.
https://www.bigmacktrucks.com/topic/10767-cf-mack-flywheel/#findComment-40777
What is the condition of the one you have now, is there any reason you couldn't have it machined?
-Remember, finding a used one is a 50/50 gamble, you may have to get IT machined depending on it's condition. Plus the weight and the cost of purchase may just make it cheaper to have yours machined in the end.
https://www.bigmacktrucks.com/topic/10767-cf-mack-flywheel/#findComment-41208
