Hi all. Can somone please tell me why i am cracking pistons ?
Engine E 6 320 standard fuel not over heated oil squirters ok
timing 24 degrees by plate on pump and by book
Re built jan 07 242858ks
No 2 and No 4 cracked 6 / 08 340480 ks
Now. pistons are genuine Mack from Mack but made in INDIA
all after production pistons made there now. Never had any trouble ever before
Got me beat.....Mark
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/
Are you possitive the piston coolers are aimed correctly!the coolers got to hit the piston correctly or they can over heat!We have cooler targets to check em after liner install.
the spray for the cooler needs to head basicly straight up from the nossle hitting 5 or 7 oclock on the piston, stick a welding rod in it and see where its heading!
as you said the injector spray looks fine
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40839
Hi fjh I have the target for the piston cooling jets. They were in the
spec and careful when fitting the rods down the bore. The brown stain
inside the piston is uniform on all........ Mark
Heat checking on a high millage engine is not uncommon. What condition were the rings in? Damage from detonation is more common to a gasoline engine, but from what I can see the top ring land has had too much heat. Check the ring ends to see if they have butted. If that is the case slip one into the bore and check the end gap. I can't think of another reason to fracture the second ring land. If the ring gap is correct, and the rings have butted together, You are putting too much heat into it.
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40873
bolweevill thanks
Now the engine was fully Rebuilt
pistons rings liners whe whole deal Jan 07
ring gaps spot on
done 41833 ks cracked 2 /4 nov 08. put it down to bad luck
Now No 5 cracked in the steel insert, done 139455 ks sept 09 piccy later.
the thing is pistons 1 3 6 are still good
standard fuel pyro never goes over 4/12 to max 5 degrees C.
owner driven by me. Sitll 99% cross hatch marks in the bores.
Me thinks crap parts. Remember the original pistons were in there for
11 years and were still serviceable.......Mark
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40874
bolweevill thanks
Have to agree!
An old Bob Serger song comes to mind!
Take them old pistons off the shelf
put em back in there by yourself
todays pistons anit got the same soul!
So put em back in there respective holes.
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40880
Have been thinking of PAI rebuild kit this time
have used PAI in the past with no worries at all
if Mack can only supply the after market stuff
they have lost me.
Is PAI still made in the US? may bee they have better quality controll.
going at this rate i will have to put zippers on the heads........Mark
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40883
they have lost me.
They still have pistons listed on their on-line catalog, didn't say who made them. 770 822 1000 is their number.
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40894
they have lost me.
Gday mate. I got a PAI kit from gleemans and it was a good price. Its a 285 EM6 and its used oil from day one. I took the heads off and all of the bores are shiney. Its had RX super in it the whole time. Its done about 150000Kms. Hard to work out, and it may be a once off, but if I had to do it again I would be thinking of using genuine parts. Skip
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40896
Thanks Bollweevil Gleemans have a kit in stock
Skip don't know why your's pollished the liners
I use rx super and never had an oil related problem
My engine has 98% hone marks still in the liner
Its just crap parts. Saying that it most probably
was a faulty batch
pistons 1 3 & 6 are still good
piston 5 was still good til this week
2 & 4 cracked at 41833
2 & 4 replaced at that K's still good
Mark
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40912
Picked up the Re build kit. It seems that all the 2 valve pistons
are of the later design. I am sure that it was just a faulty batch.
They seem to be a little better finish. After a lot of reserch i now know the
company's that manufactured them. Never had a piston failuer in 30 years of
Macks. The PAI Kit was $2772.25 AUD so not too bad. Time will tell.........Mark
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-40971
Regarding the difference in piston top configuration, I recall seeing a Mack service bulletin back around the mid 90's discussing that change, and the fact that more combustion "rattle" would be noticeable in engines fitted with the new design pistons.
I put a set of those updated Mack pistons into a 237, and also put a set in a 285 back around that time and never had any problems with them. But that's when Mack parts were still being made by Mack and not subcontracted to some low bid company in India.
Perhaps V*lv* has subbed out all the Mack replacement parts manufacturing to 3rd world sweatshops.
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-41004
Thanks HK.
I have been pulling my hair out or what's left over this.
They jus talk round in circles down a Mack now as they are non current item now
I have learned how to decipher the markings and serial No's on the piston tops
and the different suppliers. All made over seas now.
I put it down to a bad batch / quality controll on the day.
The set i have now is fron a different builder and looks a better finish itm
I'll put them in and see what happens. Thanks Mark
https://www.bigmacktrucks.com/topic/10775-cracked-pistons/#findComment-41010
