mackmech
The engine was an out of chassis re build
Piston to liner height checked under spec
New liners pistons fitted ring gap checked
over boost? "standard fuel" runs 21.75 boost. spec is 21.6
Now pistons 2 & 4 cracked in 4100.00 Ks
it took up to 139.00 Ks to crack No5
How come pistons 1 3 6 are still good.......
If pistons were hitting the head i would not be asking questions
it would have dropped a valve by now. Keep guessing........Mark
Mike i will let you know how it goes. Should be good
That particular brand uses MAHLE brand, Google them up
very good brand. Certanly better than the other brand........Mark
Mahle earned their reputation in Formula Racing. They are certainly not a bad choice as far as pistons go. I have used their coated and un-coated pistons
in race engines and hot street engines, with good results.
