looking for a few parts for a 63 b61s tandem dump need a right front lever shock link and bottom mounti have the shock ..... if any one had a good set of 8 1000-r20 tires lug pattern , out side door locks dont have to work just fill the hole. a couple of the thermodyne hood emblems used, 2 b61 hood emblems im sure / know the list will get bigger
https://www.bigmacktrucks.com/topic/10885-shopping-list-for-b61/
FYI: I needed at least one new shock link and couldn't come up with much so I made a new pair out of threaded rod and heim ends. Ran new grade 8 bolts through the original holes and works fine, so far. Not that they move much anyway :pat:
https://www.bigmacktrucks.com/topic/10885-shopping-list-for-b61/#findComment-41244
Matt Pfahl had some original swivel ends for the B model hydraulic dampers,
although the heim ends work well.
Spring U-bolt material in the correct diameter works really well for the link,
and the spring shops can thread it for you.
When you get a list of the pieces you are looking for - post them here and we
will try to help you out.
Good luck!
Paul Van Scott
https://www.bigmacktrucks.com/topic/10885-shopping-list-for-b61/#findComment-41252
