Guys,
My B has a Maxidyne that someone installed with a Duplex. (Truck was originally a B-60X). Also 9.05 Gears in a 29,000 rear. I'm thinking I'd like to put a 6 speed in to really take advantage of the Maxidyne.
Any words of wisdom out there from those that have done it? I would also probably change the rear to a 4.60.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/
the 6 speed is Direct transmission in top gear. with 4.90s you will have a hard time doing 55MPH. you might consider an Overdrive trans or 3.87-4.17s for a play truck.
Trent
Trent- 4.60, not 4.90 The truck has 11:00 x 24's so as I do the math, with 4.60 gears at 2100 its good for 61.9 vs about 68.4 for 4.17's The 4.17's would probably be better because at say 1950, I would be doing about 63- and if I saw a "large car" bearing down on me in the mirror, it should do 68! The issue is I can find a 4.60 CRD 62's or CRD 118's are tough to find.
My bigger question is are all the mounts different and am I into drilling new holes etc??
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41604
You will most likely be fabricating your mounts to the frame. I would obtain from a yard the mounts on the transmission. You can utilize the original frame bracket mounting holes in that scenario.
Fabricating the mounts is not difficult with patience.
Very few Maxidyne series drivetrains were put into B models. Those that were were a "test bed" as I understand for the concept.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41606
When you go transmission shopping, also get the trans mounts that bolt to the bellhousing and the mounts that bolt to the inside of the frame.
The frame width at the transmission mounting area may or may not be the same on your B model as on the "donor" truck, but having those frame brackets will still save you some work even if you have to modify them to fit.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41672
Hi Herb, did the later "Maxitorque" transmissions use SAE flywheel housing mounts and get away from the transmission case boss mounts? I've never seen a Mack trans use the flywheel housing to mount to, only seen the SAE mounts used with Spicer, and Fuller transmissions. I've not been around anything newer than 1985 though.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41695
Hi Rob.
When I said "bellhousing" I was referring to the transmission half of the bellhousing,with the mounts on it, just like what's on your 107 series transmissions.
On the later T200 & T300 series Mack transmissions the trans. bellhousing is integral with the main case, and the mounts are still on the trans, just rear of the bellhousing to flywheel housing interface.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41697
Hi Rob.
Hi Herb, now I follow. I was thinking the housing and main case did not separate although I should have known because I've physically unbolted them in the past. The memory I retain is slipping I guess.
Thanks,
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41698
I got to thinking some more about this during a bout of insomnia last night.
Your duplex is undoubtedly set up for a push type clutch (either single or double disc), so the flywheel & clutch from the original Thermodyne engine was bolted onto the Maxidyne to accomodate the duplex transmission.
The Maxitorque transmission will be set up for a Spicer angle spring pull type clutch, so you'll have to get the correct flywheel & clutch and stick it on your engine in order to install the Maxitorque transmission.
Since the original clutch was push type and you're switching to a pull type, you'll have to re work the clutch linkage to pull instead of push. You might want to consider adapting a suspended under dash clutch pedal &
clutch actuating cable from a DM or R model.
Also, you'll have to use the correct speedometer drive gear or adapter for your truck's rear axle ratio.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41741
HK (Herb?) Thx- I would bet you are correct. the truck is a 56 B-60X and I'm told the maxidyne was installed in around 79. My bet is the gas job was gone long before 79 when a 673/Duplex was installed. Maybe I should just live with it. The truck was in use up until a couple of years ago- not a lot on road miles but it does work- I drive it like a six speed- either upshifting while in first or any gear in between. No split shifting though- I had too many old timers tell me it is very easy to vblow the back of a Duplex out with all that torque.
https://www.bigmacktrucks.com/topic/10978-duplex-to-maxitorque/#findComment-41812
