Is there anyone out there that knows where I can get a fuel pump for the EN540 engine or even parts to rebuild it? If I dont start the truck at least every couple of days it seems like the gas syphones back down to the tank, and I have to reprime system. Any kind of help would be great.
Mack and OshKosh enthusiest in central CT
https://www.bigmacktrucks.com/topic/11003-en540/
The problem you explain sounds more like carburation than fuel pump related. It sounds like the float bowl is draining. If it is Zenith carb, the two brass screws/caps in the lower part of the float bowl could be leaking.
https://www.bigmacktrucks.com/topic/11003-en540/#findComment-41718
  • 15 years later...
image.thumb.jpeg.2094c6e46dee5723a60ee0692468e7b2.jpegim not sure what you are needing,, specs?  are making your own pistons?  this book has a lot of part  numbers...   you may find what you need in here..
https://www.bigmacktrucks.com/topic/11003-en540/#findComment-560105
I do not have a copy of that book.  Does it have information on the EN540?  If so, can you post it?
https://www.bigmacktrucks.com/topic/11003-en540/#findComment-560121
