I recently started using Lucas oil's fuel additative in my b-model.. Its safe to run in gas and diesel and is supposed to be a top shelf product.. about $24 dollars a gallon.. 3 oz treats 10 gallons of fuel. For you older macks its safe to use with lead additive also.... wasnt sure so we called lucas and spoke with a technician..good stuff!!
https://www.bigmacktrucks.com/topic/11033-fuel-additive/#findComment-41955
Allison. Where do you buy it at?
https://www.bigmacktrucks.com/topic/11033-fuel-additive/#findComment-42257
I like Howes in winter when it's real cold. I used to put a quart of ATF in the fuel tanks once in a while too, but don't anymore. The red dye in the ATF is the same as in off road fuel. There's a man in Appomattox ,won't mention any names, that has a truck leased on where I work. He also has a dump truck, bulldozer, backhoe,etc. and does excavation work. He was hauling his dozer from a job back to his shop one time and didn't have much fuel in the truck so he put just a little of his off road fuel in it to get him home-and the DOT stopped him and checked it. He had never done it before, and never had the fuel checked before but they fined him pretty heavy for it.
https://www.bigmacktrucks.com/topic/11033-fuel-additive/#findComment-42270
T-niss,
Charlie hit it on the head.. I get mine through a local trucking company. Cook Brothers. They are great.. when ever i need some part for my B -model they some how find it.. But i recently stopped in our local autozone and i saw lucas products on the shelf..
https://www.bigmacktrucks.com/topic/11033-fuel-additive/#findComment-42356
