Dear Sirs,
I am sorry to post this message here, but i have a real problem... I try to make AMT plastic model of Mack Cruise-Liner 1983. I like this truck so much! But i could not search any good pictures of the inner parts of the truck such as engine, main frame, fuel system, cabine interior and etc. Please
if you can post some pictures or please link me to it. It is my last hope...
With the best wishes,
Aleksey.
https://www.bigmacktrucks.com/topic/11247-1983-mack-cruise-liner-scale-model/
as far as what they look like or as to how and what colors to paint things ?
Mike
1953 Studebaker M275. Reo 331 I-6, Spicer 5spd-DD, 6.72 Gears, 11.00R20H tires.
1959 Mack B61T. Mack END+T 711 I-6, 2 stick 15spd-OD, 6.38 Gears, 12.00-24J tires.
1962 GMC K4500. GMC 379M-V6, SM420-4spd-DD, 5.13 Gears, 8-19.5G tires.
1969 AMC AMX. AMC 390 Crossram, borgwarner T-10 4spd, 4.44 Gears, G60-14s Front N50-15s Rear.
1975 Mack DM600. 300 Mack 6spd 4.17 gears 445/65R22.5 front n 12.00R20 rear.
1976 Arctic Cat Jag2000. 275cc twin, belt drive, steal grips.
1977 Ford F350. 351M V-8, 4spd-DD, 4.56 Gears, 245/70R19.5G tires.
1988 AMC Jeep MJ. 2.5L I-4, 4spd-DD, 4.10 Gears 215/70R15 front 225/70R15 rear.
1992 Trans AM GTA. 406SBC TBI, 4L60E, 3.73 Gears, 245/50R16 front 295/50R16 Rear.
1995 GMC K2500 6.5-T, 4L80E, 4.10 gears 7.50-16D tires. 4.56 Gears coming soon.
2007 Honda Rubicon 500cc Single, 5spd fluid drive trans, 27x10-12 Front 27x12-12 Rear.
Still in search of M52 5 ton tractor, M123A1C 10 ton tractor
Mike
Mike, thank you for the answer! I think "as far as what they look like" :) The colors are much more clear for me than wiring and inner construction.
For example, engine has a lot of different wire connections beetween the different parts. I did not see pictures of Cruise-Liner engine in the real car at all. So i need to see engine wirings, brake system with wiring, frame, engine mounting on the frame and another such things.
Aleksey.
