I have a 98 CH613 with a 427HP and 10 speed. I might have some trans issues with the 10 sp. I might swap to a 13 speed. I can use a few splits on the high side.
Can anyone give me a ball park price on what a swap might cost (parts and labor)? Other than drive shaft is there any other mods that need to be done? Has anyone done this? That's a stupid question I know some of you gears heads have done this B)
https://www.bigmacktrucks.com/topic/11415-eaton-10-speed-to-eaton-13-speed/
Output drive ratios would be the big issue. You could be going from about a .73 to a .89 depending on what you now have. Not all clutch housings are compatible, so you would need to do your homework.
