anybody replace the upper and lower insulator pads on a camelback suspension? my driver side front tandem is out of alignment. i found the pin on the pads are broken to that one tire.
any help would be great
thanks in advance
Edited by macattack
I've replaced the pads a few times,it's a little tough on the back but if you have the jacks a big air gun and a torch you shouldn't have to much trouble,you might have to heat the bolts to get them free but sometimes they come right off,depends on how long since it's been apart.Good Luck
As mentioned it's not awful if ther right tools are at hand. Most time you need to resort to heating to get things loose.
Use new bolts/hardware when you put it back together.
