Dat be correct. I place my "trust in the crust" with my ole Dodge, just tonight.
Well, now, if yer gonna be postin' pics of YOUR truck, I'm gonna post mine :thumb:
F250 at work...
...and play...
'92 Ranger at work...
...and play...
Just got the 8N home...
The Kawi...
and the '86 Ranger...a stalled project (no time, no money) buried in a corner of the garage :pat:
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44246
  • Replies 83
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I knew it was going to be a matter of time before I was in Tom's photoshop. laugh.gif
Looks like ya'll loading up to grab a Pete from someplace that's broke down.
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44273
Here is my 90 350 V8 Chevy C1500 Silverado:
Ahh yes, another one of those generic "sure hope I make it home" Chevys I've seen so many of. If you listen closely on a quiet night, you can hear it rust!
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44278
I never had either problem, she is as reliable as they come and I keep up with the maintenance on it. The next thing I need to replace is the shocks. When I got the truck they put a new motor and tranny in it and the only reason the owner was selling it was because he had a baby and needed something bigger.
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44280
Pretty decent trucks actually. Probably repaired well over a hundred through the years due to wrecks, rust, etc.... Worst consumer oriented part on the style is the air conditioning/heating system as the airboxes hold drip water from the cowl area and rot/corrode out. Of course we can't discount the bullshit way they fastened the doors using pins and bushings that don't last, nor the cheesy headlamp and actuator switches......
They really were a pretty solid performing unit. The 2000 and up Silverado have more inherent problems than that style did, although they are still a pretty good unit.
If I were purchasing new today and looking for long term cost of ownership, I would go with GMC although they are close with Dodge. Too much "cheapening up" to increase profit margins on the manufacturing side for too many years. Durability past warranty is not considered.
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44281
Where you use your mind to make sound judgment decisions such as whether or not to buy another truck or please Momma and massage her back and feet.
The only sound of judgment I ever hear is the "snap and recoil" of Momma's hand upside my head. I've not bought a truck in about three years so I must be catching on. I've had three given to me however. Feet? I don't touch Momma's feet; They are disgusting. After she finishes chewing her toenails and licking the inbetweens clean while watching her soaps, I don't touch em cause they're gross, (but clean). I can't get my arms around her waist from the front to reach her middle back neither, and I surely don't get around back cause she likes to fart with control, (loudly) and it smells TERRIBLE!!!
Any other examples you may think of????
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44295
LOL My 62' GMC was in that deep and kept right on a walking till i was back on solid ground my Studebaker has done that as well . . .
Biasply Super traction Tires you gotta love them . . .
Mike
1953 Studebaker M275. Reo 331 I-6, Spicer 5spd-DD, 6.72 Gears, 11.00R20H tires.
1959 Mack B61T. Mack END+T 711 I-6, 2 stick 15spd-OD, 6.38 Gears, 12.00-24J tires.
1962 GMC K4500. GMC 379M-V6, SM420-4spd-DD, 5.13 Gears, 8-19.5G tires.
1969 AMC AMX. AMC 390 Crossram, borgwarner T-10 4spd, 4.44 Gears, G60-14s Front N50-15s Rear.
1975 Mack DM600. 300 Mack 6spd 4.17 gears 445/65R22.5 front n 12.00R20 rear.
1976 Arctic Cat Jag2000. 275cc twin, belt drive, steal grips.
1977 Ford F350. 351M V-8, 4spd-DD, 4.56 Gears, 245/70R19.5G tires.
1988 AMC Jeep MJ. 2.5L I-4, 4spd-DD, 4.10 Gears 215/70R15 front 225/70R15 rear.
1992 Trans AM GTA. 406SBC TBI, 4L60E, 3.73 Gears, 245/50R16 front 295/50R16 Rear.
1995 GMC K2500 6.5-T, 4L80E, 4.10 gears 7.50-16D tires. 4.56 Gears coming soon.
2007 Honda Rubicon 500cc Single, 5spd fluid drive trans, 27x10-12 Front 27x12-12 Rear.
Still in search of M52 5 ton tractor, M123A1C 10 ton tractor
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44336
That's because of GM's soft comfort ride suspension, once loaded they SAG alot !
the 02' 2500HD used to sag bad when the enclosed mowing trailer was hitched to it, it's only a measly 12,000LB's, So i had a 3leaf helper spring's added to each side on the rear and had a leveling kit done to the front now it hardly notices that 12K-LB trailer, and that 8.1L Vortec V-8 pulls it as tho it wasn't there :thumb:
Mike
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44345
As much as I like the new Silverado's my big gripe with them is all that space in the rear wheel well.
sawzall + 12.50-38 Super Swampers = no problem
have to change gear ratios though, I could only fit Q78's on the front-36''
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44361
:D you guys :blink:
Mike
https://www.bigmacktrucks.com/topic/11568-gm-vs-ford/page/3/#findComment-44384
