hi hello i have a 1974 dm mack 10 wheeler iam gonna try and replace my brake pads on the front axle it has five spoke brake hub(dayton rims)my question is what size of socket do i need to remove the brake hub any info is greatly appreciated thanks
Unless you are going to be replacing the brake drum their is no need to remove the drum from the hub. Wheel, Hub, and drum will come off as one unit. Back the brakes off, and just remove the spindle nut and it all slides off. Make sure you use all new hardware and replace the pin bushings. Check the s-cam bushings while you are in their.
https://www.bigmacktrucks.com/topic/11705-repairing-my-brakes/#findComment-44910
