Hello all! I have been looking for a B61 for a few months now. I ran across a B53 and would like to know the difference between that and a B61? Apparently this B53 has a heavy duty front end? Is this the difference or what. Another question is about the turbo B61's was that an option or what? Iv seen them both ways. Thanks!
-Jeremy
https://www.bigmacktrucks.com/topic/11707-difference-between-b61-and-b53/
The B53S was a single frame concrete mixer chassis that came out in '63. I think B-61's were made during the entire B-model run. There were more B-61's made than any other B-model.
in the back of my photo archive mack book it lists the B53 as built from 1962-1966 with 2,625 units built.
I may be wrong, but I believe that the difference is that B-53's are tri-axle or quad-axle. The grill was different than the B-61.
this may not be true but from looking at the two, it looks like the b53s were made allittle more heavy duty to accomodate the heavy concrete. the b61s were used more as tractors and such.
They were available as a triaxle according to my book, mine is a tandem axle.
Checked into it and previous posts are correct, the B-53 was a mixer chassis. Heavy duty and light weight. No single axle, only tandem or tri-axle. The later ones may have had a quad available - I do not have that information. Not sure but it looks like it might have been a short model like the B-57. It would have been the forerunner of the DM-600 (Dump/Mixer).
it kinda looks shorter but i think its the same length as a b61.
If I remember right in one of the Mack books(maybee Montville) there is a picture of the last B model produced.
Again if I remember right it was an all wheel drive B-57 cement truck. Merry Christmas all and keep the rubber side down.
