I have a 1960 B61 with a 1984 E6 engine and 6speed with Lo-hole trans , I plan on replacing with T2090 mack 9speed has anyone made that swap and if so how did it go and what parts would I need with the 9speed other than gear shift and air shifter , I am currently using the 84 mack trans mounts with a pull clutch would appreciate suggestions --thanks --Rocky
https://www.bigmacktrucks.com/topic/12069-transmission-swap/
It should be just bolt in other than the driveshaft might have to be longer,the shifter,transmission yoke should interchange,get a high-low splitter from an old roadranger.
https://www.bigmacktrucks.com/topic/12069-transmission-swap/#findComment-46635
