Makes you wonder what goes through peoples minds. Obviously not much :rolleyes:. At least have a pusher truck to help for cripes sake. Hey John, I bet your DM800 would yank that load with no problem. :thumb:
-Thad
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/
and he was going nice and steady like a good drive would. no throttle revs? must have been a weak joint? front end was looking a little light. Glad his brakes held!!!!!!!
True, but that is one hard looking pull. Without the proper axles or help from a pusher its no surprise the drive shaft let go. Either he is a company driver just doing what he was told or someone who bit off more than he could chew.
-Thad
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47327
if you watch you'll hear the drive shaft catch the truck wiggles and continues on a little ways further then it let's go :thumb:
a Mack M123A1C would have made that pull easy with the big ol brute of a V-300 Cummins rapping up the hill in the lo hole humming along at 2,800-3,200rpm's while them twin 65K-lb rear's with 10.11 gears howled the whole way . . .
I love them military truck they ID tag 65,000lb yet when you run the part number off the rear ends they come back as 120,000LB rear end's and the 18K-lb steer axle come' back as a 52,000lb steer axle . . .
the GI under rating system why do they do it ?
Mike
1953 Studebaker M275. Reo 331 I-6, Spicer 5spd-DD, 6.72 Gears, 11.00R20H tires.
1959 Mack B61T. Mack END+T 711 I-6, 2 stick 15spd-OD, 6.38 Gears, 12.00-24J tires.
1962 GMC K4500. GMC 379M-V6, SM420-4spd-DD, 5.13 Gears, 8-19.5G tires.
1969 AMC AMX. AMC 390 Crossram, borgwarner T-10 4spd, 4.44 Gears, G60-14s Front N50-15s Rear.
1975 Mack DM600. 300 Mack 6spd 4.17 gears 445/65R22.5 front n 12.00R20 rear.
1976 Arctic Cat Jag2000. 275cc twin, belt drive, steal grips.
1977 Ford F350. 351M V-8, 4spd-DD, 4.56 Gears, 245/70R19.5G tires.
1988 AMC Jeep MJ. 2.5L I-4, 4spd-DD, 4.10 Gears 215/70R15 front 225/70R15 rear.
1992 Trans AM GTA. 406SBC TBI, 4L60E, 3.73 Gears, 245/50R16 front 295/50R16 Rear.
1995 GMC K2500 6.5-T, 4L80E, 4.10 gears 7.50-16D tires. 4.56 Gears coming soon.
2007 Honda Rubicon 500cc Single, 5spd fluid drive trans, 27x10-12 Front 27x12-12 Rear.
Still in search of M52 5 ton tractor, M123A1C 10 ton tractor
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47328
Almost looked as though he didn't select a low enough gear, lugged the engine, and attempted to downshift on the hill....and snapped the drive shaft when the weight of the truck + gravity fought the torque + gearing of the engine & transmission...the drive shaft proved itself to be the weak link.
I've seen a lot of coal haulers attempt to "get a run" at the coal pile, start lugging & slam the transmission into the next lower gear...surprised more of them haven't dumped their drive shafts right there on the coal pile. Then again, the company trucks are cut back to MAYBE 425 HP and they are only 80,000 pounds...not 600+ HP pulling 400K :blink:
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47498
I like to watch people do that, just for pure amusement.
Only we've got quarries around here with some pretty steep drives out. You either see a guy creeping up in first gear or sitting there with parts strewn about.
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47513
I usually use 2nd @ 1600 RPM's...unless you consider L to be 1st, then I'd be in 3rd...unless you are counting splits as gears, then it would be 5th or 6th depending on where I've got the splitter lever....
If you can't push a little harder on the throttle and accelerate, you're in the wrong gear. :thumb:
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47517
That would be every is the wrong gear then in my 6.5-T :thumb: to bad they don't let you test drive'em loaded :angry: or i would have never bought it, i have tossed about ever up grade to it i could in between break downs :thumb:
quick as heck empy doggy as piss loaded . .then again should i of expected any else from an engine designed by Detroit :thumb:
I'm not saying it doggy under 12,000LB load or 7,000LB load it gets doggy under a 4,500lb load or 3,000lb load starts slowing down at a 1,500lb load n by 4,500LB's its a puke.
Its got 4.10 gears came factory with 32" tire i dropped down to 30" tire it got better but not enough to notice it so i went back up to the 7.50-16's truck really should have 4.56's . . . high reving low power turbo diesel sure sound's like an 8V-71 to me :thumb: . . .
Mike
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47747
Mike
Dang...my Mack has 4.17 rears with 44" tires (11R24.5) grossing over 80,000...walks up just about anything I can get traction on :thumb:
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47752
yea but my 6.5 is a 3/4ton pick up truck . . . Your Mack has 11R24.5's ? My Mack has 12.00R24's there 49" tall i have Goodyear G177's :thumb:
My Mack will run everyplace yours won't :lol::thumb:
I Run these Quality tires:
GoodYear G177:
Firestone T831
Mike
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47928
Mike;
The reason I think they "under-rate" the axles,(and probably just about everything else) is because they figure there may be soldiers' lives on the line,and military drivers are inclined to use a truck pretty hard under normal circumstances,and much harder under fire,so better to not leave anything to chance;make sure the truck was up for whatever might come up. :idunno: Of course,I could be wrong. I think it's kinda like when the Power Company here bought new trucks,they used to spec them out just as tough as was possible,figuring there'd be a high percentage of drivers who "could break a steel ball in a sandbox." Cheaper to order it right to begin with than have to keep fixing stuff.
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47942
Mike;
If you've ever talked to a lineman (or at least the ones around here) they'll tell you that their first priority is to get to the line they have to fix...even if it means charging full speed through the ditch into a muddy field. The wrecker or another truck will be along in a while to pull 'em back out, but they have to get to where they need to do the work in order to get the power back on...
...and when the drivers ain't gotta worry about the repair bill, ya gotta spec it tough :thumb:
https://www.bigmacktrucks.com/topic/12199-awwww-poor-peterbilt/#findComment-47944
