I recently refurbished the 40 gal square tanks on my B-61lt. Trying to find tank straps for them. The Mack straps I recently picked up from the Mack shop were wider at 2 inches and the t bolt was also larger. I would have had to drill out the mounting brackets and I didnt want to do that if I didn't have to. I believe the straps were 43 inches from t bolt to t bolt and 1 1/2 inch wide. Does anyone know of any place to purchase the correct straps. Thanks.
https://www.bigmacktrucks.com/topic/1220-40-gal-tanks-b-61/
I would think you could have a fab shop make you some up. Maybe out of stainless?? Oh...that would be pretty. Roll the ends, install the t-bolts and weld the loop shut. Oh, the possibilities?
I think I have some used ones left out back on some frame brackets. If you don't have any luck let me know and I'll take a look.
https://www.bigmacktrucks.com/topic/1220-40-gal-tanks-b-61/#findComment-6282
Just did the exact same job, tanks are at the powder coater now. Had the straps chromed- pricey at $200 but I was getting the bumper and breast plate done too so I was reckless. I could measure the straps so you could have them made. I intend to put a sealant in the tanks when they get done baking at the powder coater's place. They were beginning to rust through under the I.D. plates and I was afraid the new ULSD fuel would break up 45 years of sludge and send it to my injectors
https://www.bigmacktrucks.com/topic/1220-40-gal-tanks-b-61/#findComment-6299
