E6-350 4 Valve Timing Cover
Hi, I have a 1988 E6-350 4 valve engine that came out of a MH cabover that I want to put in my 1987 Valueliner. The engine has the cast alum. timing cover on it now, but I need to change to the stamped steel cover due to the front crossmember on my truck. All the Mack engines I have seen with the steel cover have Ambac Injection Pumps and I have the close coupled Bosch pump. Is it really just as simple as swapping the timing covers? Thanks for any advice, Kevin
