Transmission Ratios
Guest Macks and Brockways
Where can I find information on the ratios on the different transmissions. Manly looking for the t2000 series stuff but would not mind the older stuff also. Do any of the t2000 series have two overdrive ratios, I read elsewhere that the final ratio was .60 on most but thats a jump from 1-1, did any have say a .8 ish next to top gear? Thanks
https://www.bigmacktrucks.com/topic/1243-transmission-ratios/
The 5,6,7,& 8 speeds are all .6 overdrives. They all are also direct in the next to high gear. Most trucks with these trans have 5.73 rears. They are like driving an old 6sp 2 stick. You wind em up tight and then wait for the tach to drop to 1300 to find the next gear.
https://www.bigmacktrucks.com/topic/1243-transmission-ratios/#findComment-6342
