Where does one purchase the flange head grade 8 shoulder bolts for mounting suspensions to the frame? I've never purchased them before and didn't know if they are a dealer item, or a hardware supplier fastener.
Thanks,
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/
hi,
I got the last ones I needed for Walts R 205 from carr products, It was refered to as a" body bound bolt" You had to specify the diameter of the shoulder, You had to clamp the two pieces toget her(I just used regular bolts) then ream the hole and then press the bolt in( very slight press fit, but snug). removed the next bolt, reamed the hole and installed next bolt until done. They dont want to give them away either!!!
Fred
15 gears...no waiting!
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50215
hi,
Fred
Hi Fred, is that Mcmaster-Carr? I've never heard of Carr products themselves. If different would you pass the phone number along? I'm working with the air ride cutoff you and I picked up in Ohio mounting under another truck.
Thanks,
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50217
Thats the same company.... I forgot the Mcmaster part.. opps
Fred
Yea,..... looks like someone FORGOT tha SHIFTING VIDEO with someone on tha hood also. All of the American Truckers would have loved it. :pat:
Only a few of us Want-a-Be Truckers could have benefited from a nice educational video. It would have been a one of a kind. :(
mike
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50230
Thanks,
Rob, I can send ya one of my See clamps.
mike
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50231
mike
Sure, and I'll send you a video of my See Food.
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50234
Thanks,
Here's where we get them:
http://www.takeittoaccurate.com/4SuspensionWarehouse.htm
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50275
http://www.takeittoa...onWarehouse.htm
Thanks Herb, when my hard drive died a couple months ago I had lost that link you'd sent earlier.
Getting the rears out of the B67 this weekend. Finally back on my feet after wrenching my back Tuesday at work.
Thanks,
https://www.bigmacktrucks.com/topic/12794-suspension-bolts/#findComment-50279
