Been several discussions lately about what engine will mate with what transmission so I'll post this chart to hopefully help someone in their quest:
SAE Flywheel Housings.pdf
https://www.bigmacktrucks.com/topic/12904-sae-flywheel-housing-sizes/
Thanks Rob, I know I need all the help I can get. I know I have not spotted this in any of my manuals. Actually I have several manuals that date back in the early to mid sixties and to me they are mostly basic. The clutch etc. section in the largest manual I have, I bought it off of ebay and alot of the pages were stuck together. I sent them to our Historical Library and they put the pages inside of a humidifier and that still did not loosen the pages, only curled the tips up. I have the Mack Manual that was sent to me from the museum but it still does not get down to the nitty gritty. But I appreciate all that I have.
Thanks Again
mike
Frst thing I did was copy those tables, then ship a copy off
to a friend of mine that is into 4 and 6BT Cummins.
Good stuff!!
While you're here, any one got a rockwell front axle WITH brakes for my 'R' model??
Looks like there might be some trips to and from the West.
Might be some cheap shipping in here some place!!!
Packer
Keep a clutchin'
Good stuff!!
Packer
No Brakes but you don't necessarily need to stay with Mack for the brakes. Those spindles and brakes are used on a multitude of trucks. Pull the hubs and get the bearing numbers, and spindle numbers, then hit a "Hollander" manual for conversions. If the spindle is the same from another truck, the brakes will work. Be sure to change the treadle valve to something that will limit front brake application pressure or run a limiting valve.
I've got a couple of 700 series parts needing to come this way. As you get closer in time, I'll let you know.
