i had a 13 spd overdrive with 373 ratio, in the 55mph states it turned 1200 rpm's it lugged to much
i now have a 13spd no overdrive and 393 ratio it seems to do a great job at any speed.and it gets better mpg at 70 mph than 60 mph. and pulls like it's pissed off.
it would seem if i had overdrive i would need 411 ratio.
i see trucks with overdrive and 342 ratio how can this work????????
i know the guy's specing these trucks are smarter than me, but what am i missing????????
https://www.bigmacktrucks.com/topic/13091-gear-ratio/
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
What model transmission do you have? I didn't know there was any recent 15-1600 series 13 speeds that did not have overdrive.
Dave
i dont have the build sheet on my truck, i understand it has a slight overdrive, but not like some of the stuff thats out there.
i guess i should have made my question more clear. i cant figure how to drive a truck that you have to wind up that tight to get it in overdrive, and at the slightest grade its lugging its guts out??????
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51472
a friend of mine got an 06 pete. i had never driven one so i took it down the road and back about 20 miles.
dont know anything about them but was told it had a 475 cummings and 10spd overdrive i had to wind it like hell to get it in o/d then at first hill it fell on it's face, so rather than saying hey buddy i think your new truck is a piece of crap, i thought i would get on here and see what im doing wrong.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51475
That's the beauty of a 10sp. I think the newer ISX's and especially the Cat Accert motors have a very narrow powerband and the high(numericaly low) gear ratio is needed to keep the motor at 1300-1400rpm at cruising speed to get decent mpg.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51483
if its a B series Fuller it would have a .86 OD in high hear roughly the same as a half gear down in a A series, pretty rare, I was under the assumption your Rawhide had the Mack 13
yes my rawhide has a mack 13
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51501
so you are saying the new macks with 342 gears and a 10spd o/d are that big of a pos.
the shut down on the pete is 69mph so i couldn't get a run at anything
it feels like it needs to be in 9th gear exept when decending a hill. uless you want to feel like you have an engine brake then you have to run in 9th also??????????????
i cant see building a truck that wacked out so i must be driving it wrong??????
65mph is around 12oo rpm's
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51503
If you're running 11R 22.5 tires, with a direct drive 13 speed and 3.93 gears engine's turning 2,200 rpm @ 70 mph.
My guess is you have an overdrive. :idunno:
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51547
My guess is that if it has more than one tooth on top, and two on the bottom, (like me) I'll never understand either.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51548
I was being sarcastic about the 10sp. They don't have many options when it comes to cruising speed, you either wind the $hit out of it or lug it. I drove 10 speeds for a few years, now I have an 18sp and love it...there's a gear wherever I need it.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51568
that would be a double over box .71 hi gear, I would think fuller 13 and 3.70's and 3.94 with a Mack 13 would be geared pretty close to the same as far as rpms in high gears, but I could be wrong
with a fuller 13 and 373 55mph about 1200 rpm's
the mack 13 and 393 55mph about 1300 rpm's
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51572
I wanna say the Fuller prolly has a .73 OD. The Mack is a .71. The only detail you are omitting is the tire size, which makes a difference. 11R24.5's are roughly 44". LP 24.5's and 11R22.5's are both around 42". LP 22.5's are going to be in the 40" ballpark.
http://www.4lo.com/calc/gearratio.htm
I would guess the Fuller 13/3.73 is riding on either LP 24.5's or 11R22.5's...either way would put the truck at 55 mph @ 1200 rpm.
I would also guess the Mack 13/3.93 is riding on LP 22.5's, which would put the truck at 55 mph @ 1300 rpm.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51592
Yup. My thoughts exactly. I just wish I had more gears in reverse....wouldn't mind a lower "low" either. I wonder why they don't move 4th gear to the high range "low" position, move all of the low range gears up one hole, and add a lower "low" gear? ...or better yet, why can't they just put a splitter on the T310ME to get the 20 forward gears w/ multiple shift possibilities in reverse, too B)
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51593
Why not just slide some 2 speed rear ends underneath your truck? 36 speeds!
I wish my 18sp had a normal speed reverse...it just creeps.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51599
....'cuz Mack don't have any :rolleyes:
Seriously, if I were spec'ing any OTHER brand truck, I'd do it....but why buy a Mack if'n ya ain't got a Mack drivetrain? :unsure:
Hell, a DT521/RT521 tandem with a 3.70/5.04 gearset riding on a 52K Hendrickson AR2 air walking beam suspension would be a pretty sweet setup...'specially with 600+ HP under the hood and an 18 speed transmission and some aggressive tires like Michelin's XDE M/S* in 11R24.5 B)
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51605
...yeah, I'm good at thinking about spending money I ain't got :wacko:
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51606
Where the hell do you go where that's needed??? lol
I'd be happy with full lockers.....aaannnnnndddd 600+hp.
I just spent the afternoon putting a new radiator in the truck, couple new air horns...next is to rig up the fog light switch for my 'chicken' lights and then some full fenders...
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51607
oops...fergot about the full lockers :pat: Gotta have it on 2 separate switches, though...one for the power divider, and a second to lock the center diffs for them situations where ya need all the traction ya can scrape together ta git ya out of a jam.
....and every time I have to dig my chain out of my side box for a pull, I'm wishing I had a better set-up. :angry:
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51614
When in doubt tach it out!
That'll be the two main things I look for in my next truck...lockers and some wheelie poppin horsepower..maybe a jake brake thats worth a shit.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51619
I prefer the "stick it in the low hole and crawl it out" approach....less likely to tear shit up if/when a wheel finds traction. I hate spinning my wheels.
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51622
they are both on 11r 22.5
https://www.bigmacktrucks.com/topic/13091-gear-ratio/#findComment-51628
