hey guys. how does a guy adjust the fuel on a bosch fuel pump on a 96 e7 300 engine. i bought the truck used and it seems the pedal is very sensitive and just the slightest bump on the road will make the truck take off like a bat out of hell. i would like to slow her down if possible. i think the previous owner bumped her up.
thanks in advance.
https://www.bigmacktrucks.com/topic/13115-bosch-fuel-pump/
  • 3 weeks later...
Yep, you got the best pump out there. It's the P-pump seen on the 94-98 Dodge pickups, Cummins 8.3, 93-97 DT408, 466, 530 IH, and the 93 Ford 7.8, I'm sure there's plenty more. Start out with pulling off the AFC(top cover with 4 bolts) and slide the little plate(fuel plate) forward. Details and pix are listed with the DT466 in the link Phantom posted, which is my site.
https://www.bigmacktrucks.com/topic/13115-bosch-fuel-pump/#findComment-52825
Easier said than done on this there is a tamper proof screw on the back side that is a real pain to get to!The fuel lines are right above It
https://www.bigmacktrucks.com/topic/13115-bosch-fuel-pump/#findComment-52827
thanks in advance.
before you go messing around inside the pump on this you need to look at the linkage . it is common for the throttel to be sensitive on a mack especially if the cab has air ride . you can put a longer arm on the pump and the jack shaft to make it less sensitive . also make sure you have the correct return springs and all the linkage is free and doesn't bind when the cab moves . also be sure the cab mounts are good ,ride height is correct. if the pump settings were incorrect you would have overfueling/smoke issues . much can be done with the linkage to slow down the way the throttel applies . if you can't resolve the throttel control with the linkage the adjustments inside are not going to help , you have wear issues with the internal linkage
https://www.bigmacktrucks.com/topic/13115-bosch-fuel-pump/#findComment-52954
