On my 1995 CH 613 with a 300 Mack motor in has hard time firing. I put on all new filters and was wondering if a drain back valve could be bad. The motor has a Primary and a Secondary fuel filter the Primary fuel filter sounds empty and the Secondary sounds full. The pump actuator solenoid is working. Need a little help here.
https://www.bigmacktrucks.com/topic/13136-have-trouble-firing-up/
