I HAVE A 1999 CH 613 E7 427 ENGINE. IDLES FINE WHEN U ACCELERATE IT RUNS ROUGH. IT GIVES A FAULT CODE OF 1 - 8 CAN SOMEONE TELL ME WHAT THAT IS .
acording to the codes on this site http://www.nortrux.c...hp?page_id=1033 the fan is not working correctly!that should not affect the running of the truck! An 8-1 code would !No#1 unit pump failer!
THANKS I WILL CHECK THAT.
I have the same truck but a 96 model. I had that problem and it was a sensor in the pump and they are proud of those babies. Sensor alone was around $800. Complete rebuild for pump and injectors was about $2800. Getting any unspent fuel out the exhaust?
Ha! I feel your pain. I had mine 'checked' out the other day at a reputable diesel joint. The guy more or less said that I need a complete overhaul of the fuel system...to the tune of about $4,000. To do anything really, the pump has to be pulled off and if you're going to go through that much trouble, why not just do it all. He 'thinks' that the econovance deal is not doing what it's supposed to and one of those alone costs $1900...! Secondly, the slow acceleration could be a bad governor, another $800.
Too many parts, too much money on that crap. I'll just run it with its abnormally high pyro temps...hopefully when it craps out it catches fire so I can get a new one rather than rebuild.
