  MackR797-W45Holmes said:
I have a clunk type noise ocassionally maybe once or twice per mile not consitent could this be coming from the power divider section ? does mismatched tyres cause this ?
I've had that happen a few times. Usually it's a combination of two things.
1) The plungers & cams in the power divider are getting worn.
2) Mismatched tires from front to back on the tandems.
The clunking is the result of the pins & cams "jumping over" 1 notch every so often trying to compensate for tires of slightly different diameters on the drives.
Measure the circumference of each of the 8 drive tires. Put the 4 largest ones on the right side, & put the 4 smallest ones on the left side.
With a Mack power divider NEVER put all 4 larger tires on one drive axle & all 4 smaller tires on the other drive axle, as this causes the power divider to work constantly to compensate.
"Brand X" trucks with a conventional inter axle differential are not sensitive to mismatched tire as they are a regular spider gear type setup.
If you match up all the tires as I stated previously & it still clunks, then it's time for a power divider rebuild.
https://www.bigmacktrucks.com/topic/1335-mack-44000-rears/#findComment-6706
superdog, no o/d , 12speed direct air shift.
  Superdog said:
Tires could be the problem,do you have an OD transmission?
no overdrive. 12speed direct air shift.
https://www.bigmacktrucks.com/topic/1335-mack-44000-rears/#findComment-6744
