Go to the liberiary and get a "Motor's or Chiltons" truck manual from 60s-early 70s will have the info you need. There was about 6-7 different gas engines, and none were V6 all inline.
go to the links section in this site, should be a link for the b-model registry, click that and that site has downloadable pdf file that has all the specs. on the engines, bore, stroke horse power, also tells what truck they were in and all the info on the trans and ratios, wiring diagrams, cab specs front axles and about anythink you will want.
Fred
15 gears...no waiting!
https://www.bigmacktrucks.com/topic/134-mack-gasoline-engines/#findComment-488
  • 3 weeks later...
Thanks for the reply, I cant get through to the B model registry, libraries around here have mostly late model auto manuals, nothing about old trucks.
https://www.bigmacktrucks.com/topic/134-mack-gasoline-engines/#findComment-850
  • 2 years later...
