Here is the diagram, If you can figure it out your better than us. Starting with the CXP, CTP, and all Macks with the MP engine, they switched over to the Volvo style wiring diagrams and they are horrible it read. The older diagrams my 8 year old could read and understand.
https://www.bigmacktrucks.com/topic/13528-2008-cxu613/#findComment-53495
Thank You for the diagram
I just cant find the F26 fuse in the fuse block
I have no power going to my switch and I checked all my fuses and all are good.
Do you know if there is more then 1 fuse block? I have only found the one just to the left of the clutch pedal.
https://www.bigmacktrucks.com/topic/13528-2008-cxu613/#findComment-53496
Look under the center top of the dash where your CB would set, a triangle shape cover with 3 screws. should be a small piece of paper with fuse location on the cover, if not I can post the fuse chart location.
https://www.bigmacktrucks.com/topic/13528-2008-cxu613/#findComment-53499
Thank You
I found the other fuse panel on the dash and found a blown fuse.
and the fuses was labeled with f numbers
https://www.bigmacktrucks.com/topic/13528-2008-cxu613/#findComment-53503
