Anyone have any experience rebuilding or repairing a cab jack? The unit that I have will release the latches, but won't raise the cab-sounds like its bypassing internally. Is there a rebuild kit or parts listing for these that is available? Thanks-Mike
Is it just me or did those buffalo wings taste like chicken?
https://www.bigmacktrucks.com/topic/13590-f-model-cab-jack-repair/
make sure the cylinders ant by/passing inside first. Then start to check the jack.
I'd also look at the bleed-down screw that you turn to let the cab back down; I found a chunk of crud keeping it from sealing on a hoist ram recently,effectively bypassing to where it wouldn't pick up weight,but would raise the arm empty. I took the screw out,used compressed air to blow the crap out of the valve seat,and smoothed the facing on the screw that touches the seat when the valve's closed a little with fine grit emery cloth. Works awesome now! :thumb:
Speed
